H2o Psi Very High
Old 03-28-2008, 02:01 AM   #1
danielstribe
Danielstribe's Avatar
Trade: General contractor/ specializing in Tile
H2o Psi Very High
Need to know what if any dangers there are with h2o psi being @ 110+ at my buddies house (with new pressure tank), seen the NEW external faucet gauge test results myself thought something was admiss when told about this high psi so I check it out first hand and was amazed for before the pressure tank was installed he barely got 20 psi. This also sparked an interest in my own psi on my home (at my current home it is by far the best h2o psi I've ever had anywhere) and found it to be 95+ psi without a pressure tank. So are these levels safe or not? Thanks in Advance DT
Danielstribe is offline
Old 03-28-2008, 07:41 AM   #2
threaderman's Avatar
Trade: Plumbing & Gas Contractor
Re: H2o Psi Very High
80 psi is the highest allowed by code in most areas.
threaderman is offline
Old 03-28-2008, 09:44 AM   #3
danielstribe
Thanks for your response still is there any danger in the psi being higher? Should I be con concerned?
Old 03-28-2008, 10:02 AM   #4
Putty Truck's Avatar
Trade: hjrafiuoashfed
Open the yellow pages, go to Plumbers, look for the biggest ads, choose a Plumber, and call him.
Putty Truck is offline
Old 03-28-2008, 10:34 AM   #5
K2's Avatar
Your washer hoses could burst, and your faucets coud drip. .. I'm curious. i only know of pressure tanks with regards to Well systems generally set around 50 psi. Are you talking about a pt on a city type system??
K2 is offline
Old 03-28-2008, 11:56 AM   #6
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Yes you should be concerned, very concerned, side effects, include but not limited to, insomnia, headaches, burning sensations on the bare skin, dehydration, and possibly death.
Ron The Plumber is offline
Old 03-28-2008, 02:18 PM   #7
Plumber
All Clear Sewer's Avatar
Trade: Sewer Rat
Can your friend swim?
www.all-clear-sewer.com
All Clear Sewer is offline
Houston Area Builders and Project Mgrs- Are you prepared for high tech homes HomeMedia Pros Business 10 02-19-2008 02:43 AM
Should High Schools bring back the trade programs?/ ruskent General Discussion 15 08-25-2007 10:31 AM
High build, high gloss urethane rhinoguy Flooring 1 02-27-2007 06:28 PM
High Work and Picture Frames 1Painter Painting & Finish Work 1 04-14-2006 05:33 PM
How many high bays on circuit? datafan Electrical 7 10-28-2005 12:07 AM
