Guess What This Is Doing
Old 12-22-2008, 05:53 PM   #1
genecarp's Avatar
Curious if anyone has seen an application like this.
http://
genecarp is offline
Old 12-22-2008, 05:53 PM   #2
genecarp's Avatar
Re: Guess What This Is Doing
http://
genecarp is offline
Old 12-22-2008, 06:02 PM   #3
FT.WORTH,TX MASTER PLUMB
PARA1's Avatar
Trade: plumbing
Storing water?
YESTER DAY IS HISTORY, TOMORROW IS A MYSTERY http://paradiseplumbinganddrains.com...bers-dallas-tx
PARA1 is offline
Old 12-22-2008, 06:04 PM   #4
Professional Instigator
rbsremodeling's Avatar
Radiant heat
rbsremodeling is offline
Old 12-22-2008, 06:05 PM   #5
genecarp's Avatar
Originally Posted by PARA1 View Post
Storing water?
yes, that is the obvious answer, why is it piped this way, whats with the circulator? do you usually see storage tanks piped this way?
genecarp is offline
Old 12-22-2008, 06:06 PM   #6
mickeyco's Avatar
Trade: Squirrel Handler
Keeping the driveway free from ice and snow?
mickeyco is offline
Old 12-22-2008, 06:08 PM   #7
genecarp's Avatar
Originally Posted by rbsremodeling View Post
Radiant heat
BINGO, it will be for radiant, the hot water is being fed from a wood burning furnace. instead of a flat plate heat exchanger, we are using this tank for heat transfer. we had some questions regarding btu,s, and recovery, but we are confident this will work. G
genecarp is offline
Old 12-22-2008, 06:34 PM   #8
Have seen it done once before as a temporary fix till the boiler came in. Worked like a charm. have you tested it yet
Old 12-22-2008, 09:53 PM   #9
genecarp's Avatar
Tommorow, we light it up, electrician coming at 11. the wood furnace requires 3 small warm up fires over 2 hrs, to allow the firebox to get up to temp without cracking.
genecarp is offline
Old 12-23-2008, 06:54 PM   #10
genecarp's Avatar
We did not get fired up today for several reasons, the most interesting thing we learned today while building the system, i will share, maybe someone will be sparred this time consuming mistake. The wood burning furnace has a damper that is tied into an aquastat and a pressure switch. The damper is supposed to open as soon as power is supplied to the unit, this opening supplies the air, to start the fire. We plugged in, the damper failed to open, we jumped the damper motor directly, it opened. So after a couple of hours of trouble shooting, we finally reached the company. Here is the deal, we opted to use a water storage tank, instead of a flat plate heat exchanger, the water storage tank was in the basement, just below the wood furnace, now when you add the lenth of the coil, in the storage tank, plus the fact that it was 8ft below, the supplied pump did not have enough pressure to push down, through the coil, and back up again, by that time the presure had dropped so low, the pressure switch would not activate----The solution, A LARGER MORE POWERFUL PUMP, we will install the new pump tomorrow, and hopefully, start making heat, Gene
genecarp is offline
Old 12-23-2008, 09:34 PM   #11
j_builder's Avatar
Trade: Specializing in residential remodeling
Just a couple of question G...why is the copper plumbing tied into the blk. iron fittings? Why isn't the water heater raised 18" off of the floor? No drain pan? NO check valves installed into the system? Where's the p/r valve? Pipe insulation around the copper (type L) of course. Inquiring minds want to know.
j_builder is offline
Old 12-24-2008, 09:50 AM   #12
genecarp's Avatar
Please be more specific, my plumber needs more detail on your questions, as far as the 18" off the ground, never done around here, we just build up on cement blocks, in case of mi or flooding. This is a 60 gall SS tank, no drain pan required. Pipe insulation will be installed, we are not done yet. He has been joining copper to blk iron for 29 years, so did his father, so we are not sure what your concerns are. Give us more detail, and we will happily respond, Regards Gene.
genecarp is offline
Old 12-24-2008, 10:48 AM   #13
j_builder's Avatar
G-While I do respect your answers to my questions I also question the longevity of the copper connected to the black iron fittings bring corrosive issues in the future. I've never connected the to different materials together for water supply lines. Going back and looking at the picture I think that I see the spring check valve installed between the blk. iron and copper just above the 3/4" elbow.
I install brass nipples/fittings when making any connections between copper(more expensive) of course. Where's James,Ron the plumber,toilet killer with their more knowledgeable experience.
Old 12-24-2008, 10:50 AM   #14
Jack of All
Dougmt's Avatar
Trade: Remodels
Galvanic corrosion
Dougmt is offline
Old 12-24-2008, 05:37 PM   #15
JamesNLA's Avatar
Trade: Plumbing & Electrical
Electrolysis can and will occur unless a dielectric union is used or a brass nipple...tee....90....Brass needs to be inbetween the copper and steel. I have seen black pipe used sucessfully like that in oil systems. I would never do that with potable water. That said on verticle runs it won't be an issue for many years, for horizontal pipe it is a service call in the making.
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
Old 12-24-2008, 06:36 PM   #16
Houston's's Avatar
Trade: Remodeling, Replacement windows,
I just put in a hot water heater today and i used galvanized elbows coming off of the water heater the to pex. is using galvanized ok?
Houston's is offline
Old 12-24-2008, 06:45 PM   #17
mickeyco's Avatar
Is pex a dissimilar metal?
mickeyco is offline
Old 12-24-2008, 07:55 PM   #18
Houston's's Avatar
Well I used a PEX male threaded adaptor as far as i know it is brass.
EDIT
Nevermind I understaind now. Thanks
One more thing what if it is a gas water heater will electro-galvanic still happen?
Old 12-25-2008, 11:19 AM   #19
I like Green things
WarnerConstInc.'s Avatar
Its not for drinking water, who drinks hot water anyways.
WarnerConstInc. is online now
Old 12-25-2008, 12:22 PM   #20
Trailer park boy
shanekw1's Avatar
Nobody that's ever drained a hot water tank.
shanekw1 is online now
i guess you never know dayexco Excavation & Site Work 9 05-28-2008 10:55 PM
Guess who I saw. JasontheMason Off Topic (Non Trade) 16 01-18-2007 09:54 PM
Guess what I got off Ebay? diego79 Vehicles 10 06-09-2006 04:01 PM
I guess its time to raise my prices... RobertCDF Decks & Fencing 5 06-09-2006 01:09 PM
