A Great Day To Break A Sanitary Tee. - Plumbing - Contractor Talk
Old 11-29-2017, 02:21 PM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,011
I'm on a tight schedule to wrap up my basement floor tile job and am running the floor into the laundry room.
So....in the process of lifting (or removing) the sink to fit the tile, I managed to crack the pvc line when the drain tailpiece wouldn't pull out of the trap. Looks like it was doped unnecessarily. Ok, so I quickly opened the wall to see where....my waste runs to the right, behind the corner of the room, behind a cast iron stack just beyond the corner, and into pvc...which is behind finished tub/shower in teh adjacent room...with fresh tile on the floor. Great day!
I had noticed earlier some dampness on the floor under this sink, which has a floor drain, Didn't think much of it..but now I know the crack might have been there...just waiting for me to finish it off when I touched the sink. No pipe support for the drain whatsoever.
This was the first time I cut pipe blind and lefthanded in a wall with a multitool.
MarkJames is offline
Old 11-29-2017, 02:30 PM   #2
tjbnwi's Avatar
Rewards Points: 4,928
Re: A Great Day To Break A Sanitary Tee.
Kowboy---is that you????
Socket Savers are your friend. Get the complete set.
tjbnwi is offline
Old 11-29-2017, 04:08 PM   #3
MarkJames's Avatar
I was cutting vertical pipe while reaching horizontally. It was tight enough to not reach my on/off switch half the time, so I had somebody plug it in once I has it lined up. Oh, and the fitting was cracked beyond salvage potential.
Old 11-29-2017, 05:47 PM   #4
VinylHanger's Avatar
Rewards Points: 8,192
I just cut sh!t out of MY way and then call my plumber and ask if its ok. :grin:
VinylHanger is online now
Old 11-29-2017, 05:48 PM   #5
rrk's Avatar
Rewards Points: 2,730
Should have just walked away, then wrote about it here expecting sympathy.
rrk is offline
The Following 2 Users Say Thank You to rrk For This Useful Post:
jstanton (11-29-2017), MarkJames (11-29-2017)
Old 11-29-2017, 05:51 PM   #6
MarkJames's Avatar
Violated my rights?
Old 11-29-2017, 05:52 PM   #7
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 1,714
Mark must be the only contractor left in N America that doesn't have a can of this in his truck:
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 11-29-2017, 09:21 PM   #8
rrk's Avatar
It is a safe bet that you will not do that again
And once it happens you say to yourself "why did I do that? " and realize the time you thought you saved is now lost 10 times over
rrk is offline
Old 12-03-2017, 11:28 PM   #9
Mordekyle's Avatar
Rewards Points: 3,750
You know it's bad when the plumber says to put some wood back in.
Mordekyle is offline
Old 12-04-2017, 08:25 AM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,706
If it makes ya feel better I blasted two 5/16" holes in a 3" copper pipe in an apartment building at 7PM last Wednesday.
Inner10 is offline
Old 12-04-2017, 10:35 AM   #11
I did that once at 7 pm. And I was an hour away from anywhere. Oh and there was no Shut off valve between the house and the cottage I was working on.
Old 12-04-2017, 01:19 PM   #12
Inner10's Avatar
You win....this was only a drain....
Sent from my Nexus 6P using Tapatalk
Inner10 is offline
VinylHanger (12-04-2017)
Finding break in boundary wire mpt1123 Low Voltage 3 05-21-2012 06:46 PM
Ya know it's gonna be a great day when.... Mike's Plumbing Off Topic (Non Trade) 14 01-21-2011 05:42 PM
Break trailer Set Up ROVACON Tools & Equipment 3 07-01-2010 07:53 PM
Ridge vent code for fire break? goneelkn Roofing 1 02-14-2010 05:41 PM
Broken Sanitary Tee J-Peffer Plumbing 5 02-06-2009 06:35 AM
