Gray Water
Old 08-19-2007, 07:10 PM   #1
Milhaus's Avatar
Trade: Renovations
Gray Water
Has anyone ever installed a gray water system for water conservation? I'm looking at tackling a little guest house and I'm curious about it. I want to make this place as self-contained as I can.
From what I understand, you tie the sinks, shower/tub, and washer into into their own line to a storage tank and then you use that water to water flowers/lawn etc. I'm sure you'd have to pay attention to what you use for detergents, but I think it would take care of the wastewater. I'll have some sort of compostable toilet so that will take care of the other problem -what do you do with the poo.
Milhaus is offline
Old 08-19-2007, 07:35 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Gray Water
You are building a breeding ground for disease.
KillerToiletSpider is offline
Old 08-19-2007, 08:21 PM   #3
Patrick's Avatar
Re: Gray Water
Thats Fu%^ing disgusting
Patrick is offline
Old 08-20-2007, 11:30 AM   #4
Plumbing/Mechanical Insp.
Moscow's Avatar
Trade: plumbing/mechanical/building inspector
Re: Gray Water
I have allowed some gray water in the city however you have to remember that a gary water system is like a leach field you can not use it for irragation. Look in appendix G of the UPC 2003 it will give you all the guid lines you will have to follow. The house that they put the gray water in loves it he ran his drain lines under his back yard trees and never has to water them. Make sure you have lots of land to use the graywater your avarage lot will not support a gray water system.
Justin
Moscow is offline
Old 08-20-2007, 11:00 PM   #5
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Re: Gray Water
I have done several gray water jobs (cabins, lodges,etc) they work out fine. As for the toilets, most of the more remote ones have been electric, some of the not so remote have been propane. Look into them, they solve many problems.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 08-21-2007, 01:02 AM   #6
Milhaus's Avatar
Trade: Renovations
Re: Gray Water
thanks for the info...and for you disgusted folks...it's not going to be a shatfield in a little closet, it will probably be cleaner than your house. Look into some time, it's pretty cool.
Milhaus is offline
Old 08-21-2007, 02:39 AM   #7
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Gray Water
I read an article on grey water for city homes, it was from Montreal Canada, they used the water from the laundry, shower and sinks, went into a storage tank where it was treated with a minimal amount of bleach then sent on to feed the toilets and irrigation. Don't know much about it, but they made one valid point (I think), you are normally using treated water for human consumption in the toilets and to water the lawn, apparently lawns aren't that fussy and potable water in a toilet is no longer potable once it enters (made sense to me). The only complaint from consumers was if you did a load of darks the toilet bowl had light blue water in it!! Health Canada has concerns about kids playing in toilets (I guess it happens) and dogs drinking from the toilet (We all know that happens). The kids I see a concern with, the dogs, well, dogs are smart enough to smell things prior to ingesting and if it don't smell right they leave it alone, mind you look how dogs greet each other, a little bit of diluted bleach water might just cure that bad breath they normally have!!
Chris
Chris Johnson is online now
Old 08-21-2007, 07:30 AM   #8
vans's Avatar
Trade: general
Re: Gray Water
I'm in the process of designing new buiding, we plan to collect rain water in a holding tank and use that for irrigation, also for water conservation their are fixtures you can install-1.1 gallon flush stool, aerators etc.
vans is offline
Old 08-23-2007, 05:44 PM   #9
y0manda's Avatar
Re: Gray Water
I am building a detached garage with a laundry and installing a gray water system. My city approves it, but must see a detailed plot plan where the lines will be. Moscow is correct check the appendix G of the UPC 2003 it will even show you what size lines need to be used and how to draw the plot plan for it. Good luck!
y0manda is offline
Old 08-24-2007, 01:37 AM   #10
Milhaus's Avatar
Trade: Renovations
Re: Gray Water
Thanks for the tips! I'll check it out..
Milhaus is offline
#&*@! Water Hammer! Mike Finley Plumbing 19 02-22-2007 11:47 PM
Is it safe to drink water from Hot water Heater? robertc65 Plumbing 14 02-04-2007 12:11 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
