Trade: Plumber
Gpm Through 1 Inch Copper Tubing
I was called out to a restaurant to give a quote on a softner, There service is 1 inch. Not even close to being able to handle there W.S.F.U. They really need a 2" service; 14 flush tanks, 18 sinks, commercial dishwasher, glass washer, and 2 urinals. In my proposal I wanted to quote them 2 diffrent ways 1st for 2" incase they ever brought in proper service size they wouldnt have to purchase a new softner, and 2nd the cheap way which is the way they will go. I was going to base the cheap way on how many gpm can flow through a 1" service @ 50 psi right off a 1 inch meter? Anyone got a clue
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
LRG WoodCrafting
![]() ![]() Trade: Woodworker Extraordinaire
Rewards Points: 8,373
Re: Gpm Through 1 Inch Copper TubingAdvertisement
Sawdust Follows Me Everywhere I can explain it to you, but I can't understand it for you. Sanding is the bane of my existence http://lrgwood.com Custom Cabinets in Hartford County Connecticut |
Rewards Points: 75
Figuring 5 feet per second I come up with 12 gpm.
The pex thing says almost 60 but I don't know what high pressure means. |
Trade: Plumber
I appreciate the effort but neither one of those sites answers the guestion of how many gpm @ 50 psi through 1" type k copper, if i had to quess it would be somewhere in between 45 and 60 gpm but I want to be dead on.
LRG WoodCrafting
You will never get an answer because you need to have a pressure drop in the calculation.
Trade: Plumber
I dont need a pressure loss measurement, Picture this.... right off the city main u have your 1 inch supply then your b-box 1 inch copper gets sleeved throught the foundation wall of a basement at that point u have 50 psi, if u cut the pipe and turn on the b-box whats your gpm... there has to be a mathmatical formula, with out cutting a tee into line and clocking how fast i fill up a bucket, customer will not pay me to do that. Would be fun thogh
Crash Test Dummy
Trade: Landscaping
Rewards Points: 1,000
Try this formula:
Trade: Plumber
Nice... I was on the wrong forum, I should of posted in landscaping lmfao
The Following User Says Thank You to kane co plumber For This Useful Post: |
protechplumbing (03-05-2009)
Crash Test Dummy
Trade: Landscaping
does 762 gpm sound right?
Crash Test Dummy
Trade: Landscaping
I d/l'ed a trial version of Pipe Flow wizard here:
http://www.pipeflow.co.uk/public/downloadlinks.php I used copper pipe, .5ft length, 50 psi. Trial version won't allow for change in pipe i.d. It's default setting is .984 inch. Fluid was water at 68 degrees f. Last edited by ChainsawCharlie; 02-28-2009 at 10:01 PM. |
Trade: Plumbing & Gas Contractor
I'm not going to do your homework for you ,but if you refer to APPENDIX E of the IPC (06) code book,you should be able figure every measurement you need,from flow/gpm,psi,to pressure loss,developed length and feet per second for various types of pipe.Hope this helps.Your likely between 17gpm - 27gpm where the water enters the bldg.
The Following User Says Thank You to threaderman For This Useful Post: |
#12 | |
Pompass Ass
Re: Gpm Through 1 Inch Copper TubingQuote:
Is it copper tubing or copper pipe? There are many variables to figure, you as a plumber should be able to look this up in your code book. Where are you located? that would be nice to know when trying to answer questions for you. |
LRG WoodCrafting
How about just disconnect the service and fill up a bucket with a stop watch running. Then you would know without a doubt.
Trade: plumbing
Rewards Points: 75
Did you know that there is also a maximum velocity to consider, this is all calculated by many factors, length of run, pressure, pressure loss through various items (meters, softeners) pressure required at most remote fixture, pressure loss through piping/ fittings. If you follow the appendix's in most code books under water pipe sizing, make a plan of the system, know the answers to the questions you can figure your GPM at almost any point of the system. Your question of how much GPM through a 1" lacks all the above, maybe the landscaper has a simpler answers but how many sprinkler heads do you need? by the way who determined a 2" meter & service was needed.
Trade: Plumber
My code book only tells me allowable W.S.F.U. based on pipe diameter....My run from the main is aprox 30' with 1, 1" 90 and 1, 1" ball valve. Is there a simple multiplyer?
Trade: plumbing
Rewards Points: 75
2001 California Plumbing Code Appendix A, Chart A-4 indicates about 32 GPM. A call to your water supplier could give you the GPM through their various sizes of meters as they also have the minimum and maximum pressure for the area.
The Following User Says Thank You to plumber1a For This Useful Post: |
kane co plumber (03-02-2009)
the pipe master
Trade: plumbing, solar
Rewards Points: 502
Simple. Add up your total GPM. Convert your GPM to FPS for that size and type of pipe. Get your developed lengths and account for any fittings with equivalent pipe lengths. Factor in diameter reduction and roughness increase with age if dealing with metallic pipe. Do hazen-williams calc. Add or subtract head losses/gains. Subtract pressure drop from minimum available static pressure at street. If you are not exceeding the speed limit for that type of pipe and the flow pressure is within minimums set forth by your code then you are good. If not, increase pipe size and run the numbers again.
Should you be selling jobs if you don't know how to size water distribution pipes? BTW, this post was completely unnecessary as the carpenter has already told you everything you need to know about plumbing. ![]()
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber Last edited by protechplumbing; 03-05-2009 at 10:54 PM. |
#18 |
Trade: carpentry
Sorry for "bumping" a year-old thread but the address to the flow rate calculator is at http://www.1728.org/flowrate.htm
(The domain name 1728.com was recently stolen). This is the third thread I've bumped so I think I'll stop right here. Good website you have here. Lots of friendly and knowledgeable members. ![]() |
#19 |
Trade: water treatment
You should check their old water softener size. Some of them are sized too small which can restrict the flow . If sized properly, the pressure drop is about 15psi.
#20 |
13 Licenses & Counting
Trade: Water well drilling & pumps
Rewards Points: 168
Disregarding friction issues, code books, etc. A rule of thumb - less than 15 GPM is probably do-able in 95% of circumstances from 1" pipe. Practically, with short runs, you can manage that in almost all cases. Sometimes you can get as much as 25, but you'd need more than 50#'s or very short runs.
Pierce Kiltoff, CWD/PI, JKA Well Drilling and Well Pumps & Filter Supply - Map Facebook Monroe, Washington, (360)-794-7300 Serving the Entire Seattle Area, including King, Snohomish, & Pierce Counties, WA |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Copper roofing | Trimac | Roofing | 6 | 07-07-2014 02:17 PM |
pex vs. copper | Mr. D | Plumbing | 68 | 05-16-2008 10:46 PM |
Is it possible to repair P.E.X tubing? | Frankawitz | HVAC | 4 | 01-10-2007 01:32 PM |
Painting new gal. gutters copper | DeanV | Painting & Finish Work | 0 | 06-22-2006 08:39 PM |
Copper vents -vs- plastic/aluminum | shopman | Roofing | 2 | 03-01-2006 07:51 AM |
Go to Page... |
