Trade: contractor
GE RO Filter
Does anyone know if a GE RO filter is supposed to drain waste water continuously???? Or is the holding tank not charged correctly?
Trade: plumbing
Re: GE RO Filter |
| The Following User Says Thank You to wookie For This Useful Post: | mics_54 (09-28-2009) |
#3 | |
Its all ball bearings
Trade: Tile
Re: GE RO FilterQuote:
A typical RO system dumps quite a bit of "bad" water so while it may look like it's continuous, it may not be. Not sure of the exact amount but I thought it's something like 8-11GAL of waste for every 1GAL of filtered water. So when you do the math, the waste discharge may run for quite a bit after filling something like a pitcher or coffee pot.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
Trade: contractor
Re: GE RO Filter
No it isn't a merlin...it has a storage tank.
Here is the issue. The water system is in a recreational home here in Alaska used maybe a month per summer. In the owners absense I shut off the well pump but leave the system presurized so the boiler has makeup water if needed. I noticed my pressure tank was at zero two days in a row with no water being used. This had me scratching my head for a while because I couldnt tell where the water was going. I snooped around and noticed the RO was draining into the p-trap when no water had been used. This would mean that the RO filter had drained about 30 gallons into the drain. The pressure tank is not a small one. I havent been back to day to check but I had shut the supply to the RO off at the angle stop valve. I just spoke to a tech plumber in anchorage he said the auto shutoff valve may be stuck. It's a new RO filter and the owner did the initial fill on it. I just installed the plumbing and componants and figured since he would be changing the filters that it would be good if he did the initial charge. |
Trade: Tile
Re: GE RO Filter
I do know if you don't turn the main supply off to the RO, it will continue to discharge. I've made that mistake before. I turned off the valve to the tank but not the main supply and when I moved a frig, water was still coming out (water line for frig was hooked to RO system).
Trade: contractor
Re: GE RO Filter
Yes the holding tank is pressurized so it can run water for a bit. It can't drain waste water if the supply is off once the pressure in the storage tank is 0
Trade: plumbing
Re: GE RO Filter
Not uncommon for a new RO not to function properly out of the box. System check needs to be done. membrane tds, storage tank pressure , product water to waste water ratio and aso. Whats the make of the unit or where was it purchased?
wookie |
Trade: contractor
Re: GE RO Filter
it's a GE from THD the HO did the initial fill so I will drain the tank and check the pressure. I just wasn't sure how much waste waster to expect. I have an install operation guide. I'm just glad thats where the water was going.
Trade: plumbing
Re: GE RO Filter
Check storage tank pressure 8psi when empty, but that will not fix a bad aso, not positive on a ge unit but most likely a external aso-just replace it. What is the gpd rating? that will tell me what type of membrane it is.very general rule is @ 3gal waste to 1gal product water this can be greatly improved with add on equipment. I Installed a zero waste water RO 1.5 years ago, I was real skeptical about it but performing great.
wookie |
Trade: contractor
Re: GE RO Filter
Thanks wookie...keep ya posted
Trade: PLUMBING CONTRACTOR
Re: GE RO Filter
123
| No filter | barnbuilder1 | HVAC | 4 | 05-22-2009 07:09 PM |
| Filter Room | Shoreline58 | Plumbing Picture Post | 1 | 12-20-2008 10:40 PM |
| Filter box on top of coil | flashheatingand | HVAC | 10 | 11-11-2008 06:46 PM |
| Filter to instant hot water dispenser | novicepro | Plumbing | 15 | 08-20-2008 12:35 AM |
| Softner or new filter ssytem | skidmark845 | Plumbing | 1 | 07-11-2006 12:59 PM |
