Gas Pipe Test
Old 03-27-2007, 07:01 PM   #1
coolmen's Avatar
Trade: hvac
Gas Pipe Test
I installed gas pipe thru garage to mechanical room and kitchen. used blue pipe dope and preasure test to 15 psi. it seems to be leaking somewhere but cant find the leak. ive been checking every seem with soap bubbles but find nothing.any suggestion on what else i can due???
coolmen is offline
Old 03-27-2007, 08:20 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Gas Pipe Test
Did you soap teat the pressure gage, sometimes this will leak at the stem on them.
Ron The Plumber is offline
Old 03-27-2007, 09:39 PM   #3
PIPES's Avatar
Trade: Plumbing and heating
Re: Gas Pipe Test
Test the fittings with soap as well(not just the joint), it's not uncommon to get a fitting with a sand cast hole.
PIPES is offline
Old 03-27-2007, 11:11 PM   #4
coolmen's Avatar
Trade: hvac
Re: Gas Pipe Test
replaced gauge problem solved
thanks
coolmen is offline
Old 03-29-2007, 07:13 PM   #5
cmvsap's Avatar
Trade: plumbing heating gas fitting
Re: Gas Pipe Test
in mass. its 3 lbs. on gas test for insp.
cmvsap is offline
Old 03-29-2007, 07:58 PM   #6
Pro Plumber
Trade: Plumber
Re: Gas Pipe Test
Test in Oregon 15 lbs 15 mins.
Old 04-06-2007, 05:00 AM   #7
jpplumbing's Avatar
Trade: Plumbing
Send a message via AIM to jpplumbing Send a message via Yahoo to jpplumbing
Re: Gas Pipe Test
connecticut is 20lbs for 20 mins.
jpplumbing is offline
Old 04-06-2007, 12:38 PM   #8
coolmen's Avatar
Trade: hvac
Re: Gas Pipe Test
here in jersey 15 psi . passed and the homeowner is now injoying his gas stove. now I i will be selling him a gas furnace . he had propane for cooking oil for heating.
coolmen is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
Gas Pipe Question.... drbigfresh Plumbing 9 02-28-2007 03:51 PM
Using Flex Pipe dirt diggler Pool Construction & Enclosures 8 02-25-2007 04:30 PM
Plugging sewer pipe that is to be retired personalt Plumbing 3 07-07-2006 12:16 AM
How to trace gas pipe? karma_carpentry Carpentry 15 11-30-2005 11:47 AM
