Gas Pipe Leak
Old 01-14-2010, 12:08 PM   #1
mics_54's Avatar
Trade: contractor
Gas Pipe Leak
What are the options on a problematic 1" joint leak when removal and re-thread would be a major pain?
mics_54 is offline
Old 01-14-2010, 12:28 PM   #2
Structural Engineer
Aggie67's Avatar
Trade: Mechanical, Structural
Re: Gas Pipe Leak
If it were me, I'd re-do the pipe. We just did a long 4 inch main, and at test it dropped 6 psi over 24 hours. It took an additional 16 man hours to find it and repair the weld, but I walked away with a signed inspection sticker and total peace of mind. (But I also include time for testing in the estimate on large jobs to cover the Easter Egg hunt for leaks. And in general my labor rate formula includes 4% for testing.)
Aggie67 is offline
Old 01-14-2010, 02:09 PM   #3
cleveman's Avatar
Trade: custom home building
Re: Gas Pipe Leak
Light it and build an enclosure around it so it won't blow out.
cleveman is online now
Old 01-14-2010, 03:05 PM   #4
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Gas Pipe Leak
Cut it out and re=thread it.
KillerToiletSpider is offline
Old 01-14-2010, 05:19 PM   #5
mics_54's Avatar
Trade: contractor
Re: Gas Pipe Leak
I got it to stop leaking.
mics_54 is offline
Old 01-24-2010, 12:06 PM   #6
jeffreyplumber's Avatar
Trade: plumbing contractor
Re: Gas Pipe Leak
a very simple fix that 1 out of 10 times will work is simply to tighten it up. of course one side is loosing if one side stops and the other dosent start leaking your good. kind of a dirty trick sometimes your luckey
jeffreyplumber is offline
Old 01-24-2010, 12:53 PM   #7
mics_54's Avatar
Trade: contractor
Re: Gas Pipe Leak
You are correct. I went to some extended measure to get another turn on the joint and managed to get it sealed. The problem, as you may have guessed is that the installed location (in the floor joist space) didn't make the use of formidable wrenches very functional. The leak was due to a partially damaged thread. I disassembled the assembly, introduced some suitable thread compound and used bigger wrenches to get another turn on the joint.
Then I told the plumber to go buy a new set of dies for his 1" threader.
mics_54 is offline
Old 02-01-2010, 03:30 PM   #8
User
TravelTradesman's Avatar
Re: Gas Pipe Leak
Mighty Putty!! LOL
J&J Plumbing and HVAC
TravelTradesman is offline
Old 02-02-2010, 10:18 AM   #9
cubfarm1's Avatar
Trade: remodel/handyman
Re: Gas Pipe Leak
Weld it, saves a lot of time!
cubfarm1 is offline
Old 02-03-2010, 05:48 PM   #10
UALocal1Plumber's Avatar
Trade: Plumbing
Re: Gas Pipe Leak
Tapered thread makes the seal, not the compound.
Keith
UALocal1Plumber is offline
Old 02-21-2010, 05:55 AM   #11
Plumbermurrieta's Avatar
Trade: Plumbing company
Re: Gas Pipe Leak
Once you have identified the leak, the solution is usually just tighting the connection. In some cases, you should put pipe dope and/or pipe tape in place seal things - definately for "pipe" fittings, questionable for flare fittings. Always be careful tightening to make sure you don't bend any pipes in the process.
Plumbermurrieta is offline
Need some help w/ a broken pipe BuiltByMAC Electrical 48 01-22-2010 11:07 AM
Chimney pipe help bsp General Discussion 8 10-23-2009 01:20 PM
Refrigerant Leak Detection Articles MechAcc HVAC 7 10-09-2009 05:42 AM
Pex tube leak under cement floor jonbjornstad Plumbing 22 12-23-2008 09:44 PM
Very clean galvanized pipe. silvertree Plumbing 14 09-14-2008 03:47 PM
