Trade: Builders
Gas Line - Can't Find The Leak
'What are the tricks to finding gas leaks in a pressurized line on new construction? We are using air right now we just can't find it....Let's hear all the tricks you folks have in finding leaks.
Plumber
Trade: Plumbing
Re: Gas Line - Can't Find The Leak
Get a spray bottle with soap and water and spray all of the joints and make sure you leave your air test on it, you'll get a bubble at the leak or leaks , also your test gauage needle valve maybe leaking spray that as well.
Abulance Driver
Trade: Contractor
Try using a match near all fittings.
Thom
could be a small hole in the body of a fitting. Took me two days to find one of those. It wasn't in the joint but the body of the fitting. I've heard of pin holes in pipe. Those are a real bitc* to find.
If you get really exasperated, take off the guage and pressure it up to 100#. You should be able to find it then, though you may blow out some of the joints. |
#5 | |
Trade: JOURNEYMAN PLUMBER/PLUMBING CONTRACTOR
Re: Gas Line - Can't Find The LeakQuote:
Trade: remodeling and restorations
Re: Gas Line - Can't Find The Leak |
Sometimes soap suds won't find a leak as happened to me one time. So on a hunch I guessed right and tighten up a union some more and that solved it. However there is a solution manufactured just for detecting gas leaks around pressurized fittings and pipe. Don't remember its name though.
If you want something more upscale, check out the combustible gas leak detectors in the Cole-Parmer catalog. I seen one for $175.00 in the 2005-2006 catalog. This instrument may also be a time saver in finding leaks fast. |
Trade: plumber
They are pretty good! But I'm not sure if it's a myth, But heard from a guy that said sometimes the pipe dope can set it off from the oder of it???? Anyone ever heard of this???
Michael |
The Grand Wazoo
I have a detector, and it has never detected pipe dope as a leak that was not an actual leak. They are indispensible for finding leaks on small underground gas lines, for gas lights and such.
Trade: Gas fireplace
Just for the record......the leak detectors WILL give a false positive on some types of pipe dope.....they even pick up the gasses from sweaty feet !!!!
Electro-Mech. Contr.
Trade: Mechanical Contractor
Try putting it near a can of regular Hercules pipe dope, most of them will go off.
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It |
Trade: Plumber
Sorry, copy/pasted & Emailed to the mrs...next time she complains, I tell her "at least I don't set off detectors".
#13 | |
Baltimore Electrician
Trade: Electrician
I've seen a pipe seam leak. The Gas fitter was going nuts trying to find it, and when he did, he showed me. (Wanted a witness, I guess). A whole stick of 1/2" had a leaky seam. At least it was cut into 3 long runs all adjacent.
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
#14 | |
The Grand Wazoo
You get what you pay for.
| Shingles Nailed Above Nail Line.. Help!! | Unregistered | Roofing | 24 | 04-20-2011 09:14 PM |
| Line V. relay w/ Low V. coil | Rugger | Electrical | 18 | 05-14-2007 09:28 PM |
| Cant find waterproofing contractor | TurnkeyConst | Construction | 4 | 05-03-2007 05:46 PM |
| Straight Horizontal Line | Speer007 | Carpentry | 17 | 12-15-2006 06:26 PM |
| cutting a line on an outside corner | Traditions | Painting & Finish Work | 17 | 11-27-2006 09:03 AM |
