Gas Line - Can't Find The Leak
Old 04-19-2007, 02:34 PM   #1
jman116's Avatar
Trade: Builders
Question
We are installing a new run of gas line and are now pressure testing it. We have a leak in the line soaped all the joints and the guage and can't find the leak. We have even removed and redone sections that maybe not installed properly to make sure everything is tight. we have over pressured the line to try and exagerate the leak - no success.
Can't find it. Anyone have any suggestions? We are about to just put gas in it and take a lighter to all the joints. (only kidding) but that is the frustration level we are at this point.
jman116 is offline
Old 04-19-2007, 04:11 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Gas Line - Can't Find The Leak
Soap all, not just the joints.
Ron The Plumber is offline
Old 04-19-2007, 04:12 PM   #3
Plumber
All Clear Sewer's Avatar
Trade: Sewer Rat
try another guage
All Clear Sewer is offline
Old 04-19-2007, 04:17 PM   #4
Custom Builder
Glasshousebltr's Avatar
Yea .....thats the ticket ....crank her on and have a smoke.
Bob
Glasshousebltr is offline
Old 04-19-2007, 04:34 PM   #5
reveivl's Avatar
Trade: Renovations
When I was a kid in England we had a gas leak in the kitchen, the guy (chap!) came and found it by using his lighter! After the initial "whoomp" there was a six inch tall flame coming up between two tiles on the floor!
reveivl is offline
Old 04-19-2007, 09:27 PM   #6
fireguy's Avatar
Trade: Fire Suppression Equipment Sales & Service
The best liqued detector is what the gas company uses. At times in the past, I have been able to beg some from them. Or ask the gas company to bring thier expensive sniffer to the job site.
What I have found in no particular order:
1. If you are using bushings between the gauge and the test port, toss the bushings.
2. Use a new gauge w/o bushings.
3. Put a valve on the test inlet. After pressurizing the line, close the valve.
4. Remove any gas valves and regulators. Plug where the valves and regulators where.
5. Do not test any fire suppression shut off valve over 10 PSI. To do so will ruin the automatic valve.
6. use only merchant couplings. The coupling that came w/the joint of pipe has straight threads,not tapered threads.
7. The connection that is the most dificult to repair is the leak.
8. put a bit of tape on the gauge to mark the pressure.
9. Dish soap is corrosive, don't use it.
I have had gas hold pressure at 20 PSI, but leak at 60 PSI. Don't test at more than the required pressure. Make the inspector show you in hte code book where you need to use more than 20 or 30 PSI.
Gas leaks can be a real problem to find. I'll take a leaky sprinkler pipe any day, they leak shut.
Fireguy
fireguy is offline
Old 04-19-2007, 11:21 PM   #7
Plumber
gmp's Avatar
Trade: Plumbing
Make sure ALL appliances are disconnected before doing any pressure test above 5 PSI on the system; the controls cannot handle any high pressure. Also, most times a leak which is unable to be found is usually an internal leak of the gauge. Pull it---plug it---test it.
gmp is offline
Old 04-20-2007, 01:27 PM   #8
jman116's Avatar
Trade: Builders
I will try your fixes but just incase i bought a bunch of lighters... It's a new run there are no appliances attached yet they are all capped. i will check the guage again but it is a new guage. We only pressure it up high to try and find the leak. I would hate to have to pulled this "crap" all apart. it's alot of pipe and fittings. All the pipe savers were not used in joining the lengths and bushings were replaced to eliminate that possible problem.
The saga continues. will keep you up to date
jman116 is offline
Old 04-22-2007, 10:02 PM   #9
jman116's Avatar
Trade: Builders
Several fittings had leaks in the fittings not at the threads. Lighters are magic in finding gas leaks.
jman116 is offline
Old 04-22-2007, 10:02 PM   #10
jman116's Avatar
Trade: Builders
only kidding about the lighters
jman116 is offline
Old 05-06-2007, 09:45 PM   #11
Grumpyplumber's Avatar
Trade: Plumber
I'm a day late and a dollar short here...but, when the test guage drops very quickly it's usually a sign of a sand hole (usually a flaw in the fitting or pipe) a fast leak is unlikely even if fittings aren't tight enough.
If you can't find the leak on a slow leak - bump the pressure up substantially until you can hear it..I'll take a "hiss" over a sudden explosion from a lighter any day.
Using a lighter is outright insane...imagine if there's even a small amount of oxygen rich air mixed inside the gas line....think of a pipe bomb.
Grumpyplumber is offline
Old 07-09-2007, 10:47 PM   #12
The plumber's Avatar
Trade: master plumber/owner
Well put. I've heard that you can jab the lead of a pencil in the hole & break it off and it will hold. I've never done this due to ethics, but I'll bet someone will after reading this. Let me know how it works out. Also heard you can take a chisel and hammer lead between the fitting and pipe threads and it will fix the leaking threads. I know some lazy plumbers
The plumber is offline
Old 07-10-2007, 01:31 AM   #13
Thom
thom's Avatar
If there is a pressure test on the new pipe there shouldn't be any gas in it yet. The lighter isn't going to do much unless the leak is enough to blow the flame.
thom is online now
Old 07-10-2007, 10:02 PM   #14
Trade: Plumber
Someone hinted at using a lighter on a live line...read the whole thread.
Old 07-10-2007, 10:18 PM   #15
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
I have used a match to find a small leak more than once and have never had more than a tiny flame at the leak. I am also talking about a leak that would loose like 5# from a 15# air test over night.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 07-26-2007, 07:27 AM   #16
vans's Avatar
Trade: general
I've heard some of the gas company/contractor have a "Sniffer" to detect leaks, can't tell you much more, Good Luck
vans is offline
Old 07-26-2007, 07:17 PM   #17
just a dumb plumber
crb555's Avatar
Trade: Plumbing / HVAC
http://www.professionalequipment.com...gas-detectors/
$120.00.... small price, well worth it. I have one on the service truck. Tech tells me it works great.
CRB
crb555 is offline
Old 07-30-2007, 03:59 AM   #18
747's Avatar
CRB
I would by one of those in a heartbeat if i messed around with gas pipes. Well i'm assuming they work.
747 is offline
Old 07-30-2007, 05:55 PM   #19
tinner666's Avatar
When I was an apprentice in Richmond, Va. We used a lighter all the time to find leaking gas mains. Didn't need it on Hi-pressure one though. Lo-pressure lines we always checked with a lighter. Freaked me out first time I saw it.
Seems that natural gas will not travel backwards through a copper screen! Pull the sreeen away from the leak, and the burning gas followed the screen.
That's how gas companies burn the excess vapors above their plants, to the best of my knowledge. Screens in the stacks.
Did it hundreds of times, and NEVER got used to it.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 07-30-2007, 06:00 PM   #20
tinner666's Avatar
I forgot to mention, we kept a 2" pipe with screen in it. We didn't just put screen against the leak and light it.
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 24 04-20-2011 09:14 PM
Line V. relay w/ Low V. coil Rugger Electrical 18 05-14-2007 09:28 PM
Cant find waterproofing contractor TurnkeyConst Construction 4 05-03-2007 05:46 PM
Straight Horizontal Line Speer007 Carpentry 17 12-15-2006 06:26 PM
cutting a line on an outside corner Traditions Painting & Finish Work 17 11-27-2006 09:03 AM
