Gas Hot Water Tank
I recently moved to a house with a gas hot water tank. Someone told me that I could have the tank stand in some sort of a holder over a drain that would be drilled in my basement in case I wasn't around when the tank started to leak. Does anyone know if that could be done, and if so, what I would expect a plumber to charge in Massachsetts to do this.
Thanks. |
#2 | |
Re: Gas Hot Water TankQuote:
How old is the water heater, as removeing it to install a safe pan could result in it failing shortly there after. Waters heater do not like to move after any set time. Life spans of gas fired hot water heaters vary, however the rule of thumb is the average life span is (5) years. If the unit you are talking about is even remotetly close to this consider replaceing it, and in the process install a safe pan. Taco Inc makes a product called a watchdog that protects the home from damange from this type of problem, it connects to the water line and shuts down the system in the event of a premature failure. Mass varys a lot in the price range for this type of replacement, its hard to give a competive price without going and seeing the system, you may be able to get a price for the installation over the phone but it is whats known as flat rate. These prices are priced quite high as they consider all aspects of the installation as the worst case installation. Good Luck Bernie |
#3 | |
It's 3 yrs. old. I looked at the Taco site. It seems as if this item would prevent the tank from filling up as it's leaking, but water that is already in it would be leaking out. What you said about things not "liking" to be moved makes sense to me. I found an item that will sound an alarm if the floor is wet. Are you familiar with these?
Thanks for your info Bernie. I appreciate it. Gerry Quote:
Gerry
Yes I am quite sure I know what you are talking about, only problem is the sensor must be maintained or it will not do anything. Also as in smoke alarms the battery must be replaced on a regular basis. I think you were on the right track to stsrt with, a safe pan is the best way to protect your home, add the other pieces and you have boat a belt with suspenders. Nothing like being double safe. Bernie |
Unregistered
Guest
Posts: n/a
anyon have tips on removeing floors and is there a chemical that you can use
| hot water tank | laybrick | Electrical | 8 | 04-25-2007 10:18 PM |
| Hot Water Tank | Bird | Plumbing | 3 | 02-23-2007 09:47 PM |
| Hot Water | Joewho | Plumbing | 13 | 11-17-2006 02:39 PM |
| Replace Hot water tank? | RussellF | Plumbing | 6 | 09-19-2006 06:32 PM |
| Expansion tank on water heater | Teetorbilt | Plumbing | 5 | 04-17-2006 01:53 PM |
