Trade: home construction
Garbage Disposal Problem
Installed garbage disposal 3 months ago and discovered it was leaking last week end. When I reached in to swipe for leaks, one of the mounting bolts fell in my hand; the other 2 were loose and heading south.
I've installed plenty of gd's and have never experience this. I bought it from ACE and it appears to be of good quality. Could vibration have loosened those bolts? Regards, Bob |
Pro Plumber
Trade: Plumber
Re: Garbage Disposal Problem
Could have, what brand is this GD?
ACE, not sure who makes their gd's. Can't figure it, I tightened the mounting ring bolts as you would expect: plenty of putty ooze, securely tight and it was fine for 3 months. I removed the unit, re-tightened the bolts and everything is fine for now. I've just never seen this before.
Regards, Bob |
Pro Plumber
Trade: Plumber
Ace is not popular with plumbers, get and install an ISE brand.
Moderator
Ace uses (is made by?) the ISE mounting ring.
I suspect this was caused by too much putty and not enough time tightening the mount. When the putty starts to ooze, you need to tighten the screws and let it ooze some more. Repeat as needed. You know you have it tight enough once you get no more significant putty ooze. What happens is the ring is tightened to the putty and not the sink, so the flange is free to move, once the putty relaxes some more under the flange, the screws are loose and will vibrate out. Check them again in a day or so and give them a tweek or two. Recheck once more and that should do it. Once the flange comes in contact with the sink, it can't compress the putty anymore and any movement is transfered to the sink, not the flange, so the screws will then stay tight. We might have to start calling you Bob14-1, instead of Bob14-0.
#6 | |
Handle It!
Re: Garbage Disposal ProblemQuote:
Allrounder Home Services
Trade: Painting, Remodeling, Handyman
I've installed the Ace disposals, if I remember correctly the fine print states that they are made by ISE.
#8 | |
Again, thanks Last edited by bob14-0; 03-26-2008 at 08:43 AM. |
Pro Plumber
Trade: Plumber
Shows you how much I go to ace hardware.
| Moisture Problem | Milhaus | Commercial Construction | 6 | 12-26-2007 02:47 PM |
| Garbage disposal leak question | back@it | Plumbing | 7 | 12-11-2007 07:38 AM |
| Garbage Disposal Backup | handymansol | Plumbing | 11 | 02-02-2007 06:51 PM |
| Sink Garbage disposal will not shut off | smcgowan@msn.co | Electrical | 4 | 06-08-2006 01:16 AM |
| Garbage Disposal | Mike Finley | General Discussion | 12 | 12-28-2005 12:18 PM |
