Garbage Disposal Leak Question - Plumbing - Contractor Talk
Old 12-10-2007, 10:15 AM   #1
back@it's Avatar
Trade: painting wallcovering and drywall repair
Rewards Points: 75
I have an In Sink Erator PRO 333 disposal and noticed this morning a puddle of water on the floor of the cabinet. Further investigation revealed that the water is dripping off the bottom of the unit - actually from inside the electrical hookup 'port'! My question is - is there a seal that goes bad inside that are replaceable or is this unit toast?
Thanks for your replies ...
Dale
back@it is offline
Old 12-10-2007, 03:07 PM   #2
PIPES's Avatar
Trade: Plumbing and heating
Rewards Points: 75
Re: Garbage Disposal Leak Question
Stick a fork in it ! it's done
PIPES is offline
Old 12-10-2007, 06:15 PM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Rewards Points: 2,000
How old is it?
Probably beyond the warranty, but just had to ask
Ron The Plumber is offline
Old 12-10-2007, 07:13 PM   #4
threaderman's Avatar
Trade: Plumbing & Gas Contractor
THere is a washer at the connection at the disposal and the 90 disposal bend.If it's not wet there your sol.If it is ,try tightening the flange or changing the washer.
threaderman is offline
Old 12-10-2007, 10:04 PM   #5
Moderator
Double-A's Avatar
If its coming out of the bottom body of the disposer, the disposer is shot. You can call Insinkerator and give them the serial # off the machine. They can tell you if it is still under warranty.
I think its dead and out of warranty.
If you recently bought the home, then you might have gotten a home warranty policy with the purchase. If so, the unit might be covered.
New York Times, July 20, 2006
Double-A is offline
Old 12-10-2007, 10:05 PM   #6
back@it's Avatar
Rewards Points: 75
'At's what I figgered!
Time for a new one! Thanks for your rpelies and opinions!
Dale
back@it is offline
Old 12-11-2007, 02:01 AM   #7
kapena's Avatar
Trade: General Building Contractor
Rewards Points: 336
If you replace it yourself, don't forget to knock out the plug in the disposal's dishwasher inlet if you are also hooking it up to a dishwasher.
kapena is offline
The Following 2 Users Say Thank You to kapena For This Useful Post:
Anderson (11-29-2017), kirkdc (11-29-2017)
Old 12-11-2007, 06:38 AM   #8
back@it's Avatar
Rewards Points: 75
back@it is offline
Old 11-09-2017, 08:01 PM   #9
tsbrewers's Avatar
Trade: Finish Carpentry
Rewards Points: 120
I know this thread is ancient, but I just wanted to post that this disposal is fixable, and the o-ring you needed was only about $2.50. The lower end badger versions are not, but the pro versions are.
maybe it will help someone in the future.
tsbrewers is offline
Old 11-29-2017, 10:32 AM   #10
PlumbersDenver's Avatar
Trade: Plumbing, Heating & Air Conditioning
Rewards Points: 12
The InSinkErator CNTR333 is rated 4.5 out of 5 on Amazon. So it's safe to say the garbage disposal itself is quality made. Have you stuck your hand down there to check if there's anything clogging it? A master plumber might be the right choice if you decide to get it replaced, assuming you want it done right the first time!
PlumbersDenver is offline
Question on how leak was "repaired" dzd9fy Roofing 33 02-15-2011 04:34 PM
Cinder Block walls, block filler and a leak...question SeanATL Painting & Finish Work 9 03-09-2009 03:33 PM
Garbage Disposal Backup handymansol Plumbing 11 02-02-2007 05:51 PM
Sink Garbage disposal will not shut off smcgowan@msn.co Electrical 4 06-08-2006 12:16 AM
Garbage Disposal Mike Finley General Discussion 12 12-28-2005 11:18 AM
