Garbage Disposal Backup
Old 02-01-2007, 01:21 PM   #1
handymansol's Avatar
Trade: Handyman Service
Lightbulb
I had a tech install a garbage disposal the other day. Everything went fine. 2 days later customer is calling to tell us the disposal is backing up.
We go out to snake the drain - 20' and all is clear. Disposal still backsup and only when you turn it on. So we go and return it and get a replacement. Same thing happens.
Not sure what is going on - I've only seen this happen one other time and we referred them to a plumber.
Any Ideas would be helpful.
handymansol is offline
Old 02-01-2007, 03:23 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Garbage Disposal Backup
How are the pipes under the sink, how is all plumbed together?
Ron The Plumber is offline
Old 02-01-2007, 03:38 PM   #3
New trap. Dishwasher connects into disposal direct and trap exits to drain pipe.
Old 02-01-2007, 04:44 PM   #4
gitnerdun's Avatar
Trade: plumber
Is the water backing up in both compartments or just the disposer side?
gitnerdun is offline
Old 02-01-2007, 05:33 PM   #5
Pro Plumber
Trade: Plumber
Double bowl sink? Does disposal tie to a tee under sink before trap? If so is this tee a baffled tee?
Lots of questions asked to get to the problem at hand.
Old 02-01-2007, 09:51 PM   #6
single sink, someone else said it could be the power of the disposal, but that doesn't jive.
Prior garbage disposal work fine - just noisy and customer wanted a quieter one.
Dishwasher also drains fine. Water drains when disposal is off. The backup only happens when the disposal is running.
Old 02-01-2007, 09:55 PM   #7
JamesNLA's Avatar
Trade: Plumbing & Electrical
I hate to ask, but did you remove the DW knock out?
JamesNLA is offline
Old 02-01-2007, 09:57 PM   #8
Pro Plumber
Trade: Plumber
OK one more question, what is the horse power, higher horse power disposals have a splash guard insert that goes into the top, running a higher hp disposal without will cause water to expel out of it, making it appear to be backing up.
Old 02-02-2007, 01:44 PM   #9
gitnerdun's Avatar
Trade: plumber
20 feet may not have been far enough. Go farther.
Old 02-02-2007, 03:12 PM   #10
Okay to answer all the questions posed (been a busy day today!).
Yes - Dishwasher knockout is open - the dishwasher is not backing up - it is the drainage exiting from disposal. See my note about dishwasher draining properly through the disposal.
Not sure what the hp is on the disposal - will check on splash guard and hp.
Snake 20 feet or more? May be a problem, but if water drains without the disposal running then I eliminate that possibility, not to mention other sinks in the house off the same main drain are fine.
The other thing I was thinking was something with the venting - maybe putting an admittance valve under the sink - maybe the water isn't able to drain because the disposal is creating an unnecessary vacuum???
Old 02-02-2007, 04:56 PM   #11
Plumber
tzzzz216's Avatar
Trade: Plumbing
How soon does it back up , right away ? Have you checked the arm coming out of the disposal into the tee , Do you have a seprate vent for the disposal , which is required now at least here anyways ?
The only easy day was yesterday !!
tzzzz216 is offline
Old 02-02-2007, 06:51 PM   #12
Moderator
Double-A's Avatar
Sounds like a venting problem, but I would not install an air admitance valve. Did this installation have a disposer before? How old is the house? Lead drains to kitchen sink? Is the sink plumbed with a 1/4 bend, then an 1/8 bend down to a wye at the vent? Have you checked the vent on the roof?
New York Times, July 20, 2006
Double-A is offline
glue/cement disposal? primo p Plumbing 1 06-19-2006 08:08 PM
remote data backup PipeGuy Technology 3 06-09-2006 08:41 AM
Sink Garbage disposal will not shut off smcgowan@msn.co Electrical 4 06-08-2006 01:16 AM
Garbage Disposal Mike Finley General Discussion 12 12-28-2005 12:18 PM
Backup from townhouse next door eddiemac Plumbing 3 10-17-2005 09:37 AM
