Galvanized ... / ... LEAD
Old 10-17-2009, 10:43 AM   #1
The Old Master
Plumber_Bill's Avatar
Trade: Plumbing & Heating
Today:
http://www.watertechonline.com/news.asp?N_ID=72786
And included in the article above is this line.
The report recommends that to fully ensure lead is not released from galvanized plumbing, full home replacement of that plumbing is the most desirable option.
Now that should generate some work in the older cities.
Bill Parr L.M.P. www.parrsplumbing.com
This and That
for a job that's up to "PAR"
Plumber_Bill is offline
Old 10-18-2009, 01:14 AM   #2
the pipe master
protechplumbing's Avatar
Trade: plumbing, solar
Re: Galvanized ... / ... LEAD
ummmm, what does galvanized have to do with lead?? I don't believe galvanized steel has any lead in it.....
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber
protechplumbing is offline
Old 10-18-2009, 01:21 AM   #3
13 Licenses & Counting
piercekiltoff's Avatar
Trade: Water well drilling & pumps
What he links to is talking about galvanized iron pipes...I'm not in that line of work, so I don't even know if that exists - but I'd assume if you can galvanize steel, they probably used to do it to iron.
However, I do have a client that is a rather large private water system (220 connections) that is replacing their well house, adding a soda ash injection system, and upgrading the well plumbing, because the low pH well water is causing the older plumbing in the houses (1970 to 1975 at the oldest) to leech contaminants - specifically, lead.
Pierce Kiltoff, CWD/PI, JKA Well Drilling and Well Pumps & Filter Supply - Map Facebook
Monroe, Washington, (360)-794-7300
Serving the Entire Seattle Area, including King, Snohomish, & Pierce Counties, WA
piercekiltoff is offline
Old 10-18-2009, 01:24 AM   #4
the pipe master
My point is that galvo pipe only contains 2 metals, steel and zinc. Where is the lead coming from???
Old 10-18-2009, 01:29 AM   #5
They add lead to the zinc bathes prior to hot-dipping materials. I'm sure they don't do this now with water pipe - but I doubt they were so sensitive in the past.
Old 10-18-2009, 01:40 AM   #6
the pipe master
I learned somthing today
What Internet lead services should do to corner the market Mike Finley Business 45 03-26-2010 09:17 PM
Lead service providers: Beware! We were FOOLED. Stonewood Online Leads Services 6 01-04-2010 08:41 PM
Lead gen site caught in the act mark the coach Online Leads Services 9 07-03-2009 11:25 AM
New idea for lead generation services, Job Generation instead MOTB Online Leads Services 12 06-12-2009 11:08 AM
Lead production companies PROJECTHR Online Leads Services 6 03-16-2009 10:23 AM
