Galvanized Compression Fittings ?
Old 11-08-2007, 07:22 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Have a job that needs a water service cut off in the crawl space. The existing water line, 3/4" galv comes up vertically from the ground then branches out to feed fixtures with a couple of T's.
This stuff hasn't been touched in 50 + yrs. If I can't break it apart and insert a copper male adapter effectively I've found galv (long sleeve) compression fittings to transition to copper or pex. These may not necessarily be Dresser Co. fittings but a China import. My plumbing supply house has the China import galv and bronze.
Question ? Are these galv compression sleeves effective / reliable ? Haven;t heard too much about them.Anyone share their experience with these ?
Further.....If I end up having to tie into the buried horiz 3/4" service in the crawl space can I use a galv or bronze comp sleeve ?
We Fix Houses is offline
Old 11-08-2007, 07:27 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Galvanized Compression Fittings ?
We generally use Dresser couplings for temporary tie in's and emergency repairs to be repaired correctly the next day. Cut the galv. in the crawl space and cut a new thread on it in place.
KillerToiletSpider is online now
Old 11-08-2007, 07:40 PM   #3
Yup.... I may do that. I guess its time to get a ratchet pipe threader set.
I just didn't want to disturb an up or down stream fittings.
Old 11-08-2007, 07:59 PM   #4
The Grand Wazoo
Use a pipe wrench as a hold back while you are threading it.
Old 11-08-2007, 08:22 PM   #5
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Call a plumber, for you have no clue, for one thing you can't just screw in a copper male adapter into galvanized, it will create electrolysis.
Ron The Plumber is offline
Old 11-08-2007, 09:06 PM   #6
The plumber's Avatar
Trade: master plumber/owner
That's right!!!!dielectric union. G couplings are a great repair for handymen, but if a plumber wants to lose my respect quick, fast, and in a hurry all they have to do is order 20 g couplings for a repipe. What tha &%^
The plumber is offline
Old 11-08-2007, 09:24 PM   #7
The Grand Wazoo
Talk to the researchers from the Copper Development Institute some day, they will tell you that you are better off using a copper female adapter over a dialectric union any day of the week. If you seriously want to fight dialectric corrosion, use a galvanized coupling and a brass nipple, then a female adpt.
Old 11-08-2007, 09:59 PM   #8
Herk's Avatar
Trade: Plumbing
Years ago, I used galv repair couplings, made in USA and they had stainless steel compression rings inside in addition to the neoprene seals that would clamp to the pipe. The foreign jobbies they're selling now seem to be missing that critical part. I never used them under a building, but only on a water service outdoors.
There are no dumb questions - just a lot of inquisitive idiots.
Herk is offline
Old 11-08-2007, 10:10 PM   #9
I stand corrected. Thanks for the info. I use brass nipples on my water heater installs, and I repipe all the way to the fixtures coming up through the floor and cabinets, but if the homeowner does not want a hole behind the tub/shower I have to cut and thread. I'll use brass next time
Mueller makes the couplings with the metal ring in the rubber
Old 11-08-2007, 10:21 PM   #10
The Grand Wazoo
A dialectric coupling and a brass nipple is the best you can do, dialectric couplings are not all that common here though. We use brass nipples for everything, tub spouts, rain shower heads, body sprays, hand showers, etc. if it is going into a copper line we use a brass nipple.
Old 11-09-2007, 08:16 AM   #11
Pro Plumber
Trade: Plumber
We don't even carry galvanized nipples except for capped nipples for our shower riser testing stubs.
Old 11-09-2007, 05:06 PM   #12
The Grand Wazoo
I carry galvanized, as there are a few high rises here that do not allow copper pipe, so all the water pipe is done in galvanized.
Old 11-09-2007, 07:40 PM   #13
Thanks for advancing my knowledge in this area. I don't care for the compression fittings too much that's why I asked the question.
As for using a copper male adapter into galv, I've seen dozens of them over the years that are in good shape. I've used them a few times also.
Prior to posting here I looked up dielectric unions and I'd say there seems to be quite mixed opinions on using them. A lot of folks / pro's say their leak prone. With that said I can use a brass adapter then copper or pex. No problem going to copper from brass you say ??
Old 11-09-2007, 07:59 PM   #14
The Grand Wazoo
Brass and galvanized steel carry some similar properties, the most important one being zinc, which is the main ingredient in dielectric corrosion, by using a brass nipple as a buffer between the two, you are reducing the amount of dielectric action considerably. A dielectric union basically does nothing more than serve as the victim of dielectric corrosion, instead of providing a means of reducing it, so the union will always be the first place that will leak.
As far as PEX goes, I have no idea, I have never used it, and more than likely never will.
Old 11-09-2007, 08:51 PM   #15
Herk's Avatar
Trade: Plumbing
No problem soldering a brass fitting to a copper pipe, especially if you're going to use it to hook PEX to the line. An 18" chunk of PEX on an incoming line is a great dialectric fitting.
I've been using PEX for a long time and far prefer it to copper. I'm reminded of this every time I see green copper pipe or a relatively new job with pinholes. I looked at one of those a couple of weeks ago - a remodel on an old house. The job was well-done - solder joints looked good, there were dialectrics in all the right places. It looked to be about 3 years old. Since it was an old house with a crawl space, the plumber had used hard copper for most of it, but used soft copper tube to go under some beams and through a concrete wall. (The copper wasn't touching concrete.) As good as it was, there were pinholes everywhere. It was on city water and, although our water is hard, it's not terribly acidic or oxygen-bearing. Still, on this job, it failed.
It's been a general opinion of a lot of people for some years that dielectric unions just don't work, that a minimum of 18" of brass is necessary. I've seen many hundreds of installations where no dielectric of any kind was used and they still looked fine after many years, just as I've seen jobs where copper was added to a galvanized system without protection and it looked as if someone had taken a machine gun to it.
Our local courthouse was falling apart about three years after it was built. Everything to code, but the copper was developing random pinhole leaks everywhere in the building. They called in engineers and ran ground wires to stakes outside, and they may have slowed the process.
PEX looks better all the time.
Herk is offline
Old 11-09-2007, 08:56 PM   #16
I could not imagine plumbing a highrise in galvanized. I would get tired of screwing seriously I hate screwing pipe together for a simple resedential gas repipe I would quit on the first day when I saw 10,000 feet of galvanized waiting to be installed. Hats off to you guys
Old 11-09-2007, 09:12 PM   #17
Teetorbilt's Avatar
Dresser couplings will last for many years, even buried underground. This is where I installed ALL of them for a municipality. 30 yrs. and no complaints! ....yet.
Albert Einstein
Teetorbilt is offline
Old 11-09-2007, 09:17 PM   #18
The Grand Wazoo
These are remodels, not new high rises, I won't go back to running work in new high rises, it just isn't worth it.
Old 11-10-2007, 08:24 PM   #19
BigMikeB's Avatar
Trade: HVAC
[quote=KillerToiletSpi;316698]Brass and galvanized steel carry some similar properties, the most important one being zinc, which is the main ingredient in dielectric corrosion, by using a brass nipple as a buffer between the two, you are reducing the amount of dielectric action considerably. A dielectric union basically does nothing more than serve as the victim of dielectric corrosion, instead of providing a means of reducing it, so the union will always be the first place that will leak.
A dielectric union, isolates dissimilar metals from making contact with each other, thus preventing a reaction in the piping. The item that serves as a "victim" would be an anode, such as in a hotwater heater. I think you mixed up the terms there a bit.
BigMikeB is offline
Old 11-10-2007, 08:31 PM   #20
The Grand Wazoo
[quote=BigMikeB;317298]
No I did not, as a dielectric union does not do that, it is merely thought that it does. Even with the presence of a dielectric union you still have two dissimilar metals and an electrolyte to carry the charge, the fact that they are not in contact does not greatly reduce the problem.
Gator bite fittings, feed back please tzzzz216 Plumbing 126 04-27-2011 11:44 AM
Compression Coupling vs Glued Joint robertc65 Plumbing 7 10-01-2007 12:58 PM
Galvanized VS Galvalum llucky General Discussion 0 09-24-2007 01:17 AM
Help, Galvanized Pipe Break wyomble Plumbing 3 10-28-2006 07:03 PM
Replacing galvanized.........YEAH BABY toddgotfish Plumbing 6 01-02-2006 02:25 AM
