Frozen Tankless WH
Old 01-09-2017, 12:49 PM   #1
bcook19791's Avatar
Trade: Carpentry/Remodeling
Rewards Points: 184
Frozen Tankless WH
Let me start by saying I'm a carpenter not a plumber but I have done extensive plumbing for my self and helped out some close family so I understand it. A good friend called me over the weekend and said his tank-less WH froze and a line inside the coil busted. I told him Id take a look at it and see if I could give him any advise. The basement was about 60 degrees. It got down to 0 the night before. I don't think it should freeze. The only thing I can think of is another cold air made its way down the exhaust pipe to cause the coil to freeze. (Still don't think this should happen). Is there something more I could suggest he do or have done when they put in a new unit?
bcook19791 is online now
Old 01-09-2017, 02:16 PM   #2
madmax718's Avatar
Trade: General
Rewards Points: 3,206
Re: Frozen Tankless WH
power vent functional?
madmax718 is offline
Old 01-10-2017, 01:22 PM   #3
Acesfour's Avatar
Trade: sewer repair and replacement
Rewards Points: 52
yeah. Proper installation is critical. Tankless water heaters usually have heat exchanger heaters but some are stronger than others. Venting length and direction can affect performance. The whole set up should be checked against the mfrs installation specification. Proper plumbing is critical.
Tracy,
Aces Four
Acesfour is offline
Old 01-19-2017, 08:33 AM   #4
ninjaplumber's Avatar
Trade: Plumbing
Rewards Points: 26
Throw in a recirc pump with a built-in thermostat and set it to the lowest setting, this way it will kick on whenever the temp starts to drop.
ninjaplumber is offline
The Following User Says Thank You to ninjaplumber For This Useful Post:
MonsieurBon (01-19-2017)
Tankless electric water heater efficiency Builders Inc. Plumbing 15 09-19-2015 09:02 AM
frozen air lines CATSKINER Framing 18 04-16-2013 04:50 AM
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 08:51 PM
Tankless inline with tank for high output / demand ferncreekjeep Plumbing 10 04-26-2012 05:28 PM
Hot water tank or tankless gastek Plumbing 6 04-06-2012 07:08 PM
