Frozen Drain Pipe
Old 01-22-2005, 11:39 AM   #1
zbwmy's Avatar
Rewards Points: 25
Frozen Drain Pipe
Bath tub drain of second floor bathroom froze in our 1 deg. winter today.
Drain pipe travels down outside wall into basement. Is there a small clog somewhere that would allow water to pool so it could freeze? I cant't see running water freeze in a 2 in. pipe. What do you think about spraying GREAT STUFF into floor cavity where pipe enters wall in basement? Should I just wrap exposed pipe in fiberglass?
zbwmy is offline
Old 01-22-2005, 02:08 PM   #2
PipeGuy's Avatar
Trade: underground
Rewards Points: 2,000
Re: Frozen Drain Pipe
Sometimes sealing around a pipe like that will worsen the situation - whatever heat was getting into the wall cavity is now sealed out. Same goes for insulation. You're right that it's unusual for a 2" drain pipe to freeze. There's probably a clog building that has been exacerbated by freezing. Liquid plumber might generate some heat and open it up. However you do it, it sounds like you have an obstruction that needs to be addressed.
PipeGuy is offline
Old 01-24-2005, 01:39 PM   #3
zbwmy's Avatar
Rewards Points: 25
I should have mentioned that applying hair drier heat to that basement elbow drained the tub.
zbwmy is offline
Drain Pipe denick Excavation & Site Work 18 07-12-2009 03:41 PM
drain pipe holes up or down? jimb317 Plumbing 9 06-06-2007 03:22 PM
black drain pipe?? pauls painting Plumbing 5 01-08-2007 10:29 AM
Ace Duraflow vs PVC Drain Line Repiping to Replace Cast Iron Drain Pipe TDELC Plumbing 0 10-16-2006 02:31 PM
How to rock around drain pipe that stick out 1/4in from stud? ruskent Drywall 11 04-26-2006 11:02 PM
