Floor Drains In Basement - Code
I am adding a 23x32 addition to my house which will be 2 foot lower than my existing basement. My existing basement is where my laundry tub will be and where I will put in a floor drain. Do I also need a floor drain in the addition basment. I was thinking code might say that I need a floor drain there because its lower than the existing basement????
Anyne know. |
#2 | |
Plumbing/Mechanical Insp.
Trade: plumbing/mechanical/building inspector
Re: Floor Drains In Basement - Code
The only reason you would need a floor drain in the bastment is if you have equpment that needs to discharge water or if there is local code that requires you to have one.
Good Luck Justin Quote:
| Help Water in Basement | LG2720 | Construction | 12 | 01-17-2007 02:40 AM |
| 2 questions - one code, one structural | karma_carpentry | Decks & Fencing | 5 | 09-10-2006 02:55 PM |
| HELP! Basement floor disaster | Profiter | Construction | 5 | 07-11-2006 09:01 PM |
| Wooden Basement? | LWF | Construction | 21 | 05-08-2006 04:17 PM |
| Landscape solution to basement moisture problem | RJC | Construction | 3 | 11-21-2005 01:34 AM |
