Flange Too High
Old 03-04-2009, 07:21 PM   #21
Professional Instigator
rbsremodeling's Avatar
Re: Flange Too High
Every time I look at this thread it gets uglier and uglier some please pull the plug and put it out of its misery
rbsremodeling is offline
Old 03-05-2009, 09:06 AM   #22
22rifle's Avatar
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Flange Too High
Originally Posted by zotparkerm View Post
is there a mechanism for "butt" joining two pieces of PVC?
Thanks
Yes. It's called a coupling.
22rifle is offline
The Following User Says Thank You to 22rifle For This Useful Post:
protechplumbing (03-05-2009)
Old 03-05-2009, 09:28 AM   #23
Handle It!
MALCO.New.York's Avatar
Re: Flange Too High
And now a Picture Presentation for any of the DIYers who are Tuned In to our Broadcast.......
This is a Schedule 40, for "REAL" PVC plumbing........
http://www.twomilesupply.com/images/atrex/100-120.jpg
For waste..Schedule 20 is just fine.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 03-05-2009, 02:05 PM   #24
plumber1a's Avatar
Trade: plumbing
Re: Flange Too High
Where are the threads?
plumber1a is offline
The Following User Says Thank You to plumber1a For This Useful Post:
MALCO.New.York (03-05-2009)
Old 03-05-2009, 06:32 PM   #25
Handle It!
Re: Flange Too High
.I do not know..............Ask those PEX guys. Maybe they might know..
Old 03-05-2009, 11:26 PM   #26
the pipe master
protechplumbing's Avatar
Trade: plumbing, solar
Re: Flange Too High
It's so simple, but I'm going to keep my mouth shut just so I can hear more hair brained ramblings from unqualified individuals.
I'll give you a hint, the tools needed are: Sawzall, 5/16 masonry drill bit, 1/4" hex driver bit, drill with hammer function.
Now, guess the materials and what to do with them.
Plumber, Repiping, Replumbing, Leak Detection, Solar Water Heater, Polk County Plumber, Lakeland Plumber, Winter Haven Plumber
protechplumbing is offline
Old 03-06-2009, 12:24 AM   #27
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
Re: Flange Too High
Closet flange ,always sets on top of finish floor material!
Driftwood is offline
Old 03-07-2009, 05:36 PM   #28
plumberbb's Avatar
Trade: Plumbing
Re: Flange Too High
There is a closet flange that will slip into the inside of a three inch PVC sch 40 pipe. You could cut the pipe flush with the floor or slab and glue the flange into the inside and it should rest flat on the floor. Most LOWES have this as a standard part on hand so it would be available at most plumbing supply stores.
plumberbb is offline
Old 03-07-2009, 07:20 PM   #29
the pipe master
Re: Flange Too High
bingo
Old 03-08-2009, 01:02 PM   #30
wyoming 1's Avatar
Trade: General contractor
Re: Flange Too High
Malco that thing in the picture? do you just stick the pipe in it or do you have to use some like liquid nails or something??? We just butt them and duck tape them here in Wyoming.
wyoming 1 is offline
The Following User Says Thank You to wyoming 1 For This Useful Post:
MALCO.New.York (03-08-2009)
Old 03-08-2009, 07:47 PM   #31
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Re: Flange Too High
The correct way to use that thing in the picture is to stick the pipe in and then use plumber's putty to seal it. Everyone knows that plumber's use plumber's putty for this.
platinumLLC is offline
Old 07-25-2009, 04:48 AM   #32
RollinSoLo's Avatar
Trade: Plumbing
Re: Flange Too High
use concrete build up a 2 inch pad to the flange. Then add a step.
RollinSoLo is offline
Old 07-25-2009, 05:11 AM   #33
slowforthecones's Avatar
Trade: scab
Re: Flange Too High
I'm going to say use cement board & grout to build up a pad to the flange, tile up a slight sloping floor?
slowforthecones is offline
Old 07-27-2009, 03:15 PM   #34
Proud Plumber
Proud Plumber's Avatar
Trade: Plumbing/Building Contractor
Re: Flange Too High
I think the jack up the house idea was the best suggestion. No complicated parts this way. Only thing I would add is foam for the gap, along wth the shims of course.
Bill
"I'd rather die while I'm living then live while I'm dead".... Jimmy Buffett
Proud Plumber is offline
Toilet and the Flange troyamuso Kitchens & Baths 22 04-02-2007 01:50 AM
High build, high gloss urethane rhinoguy Flooring 1 02-27-2007 06:28 PM
help..high end darlings and i haven't the foggiest lornmastro Painting & Finish Work 27 01-08-2007 07:57 PM
Toilet flange C.C.R. Plumbing 11 01-06-2007 02:48 PM
closet flange Vermonster Plumbing 3 02-15-2006 08:43 AM
