Fittings For Air Compressor Hose
I have an 1.5inch air line that i need to connecto to a 210 CFM 100 psi compressor. The ends are 4 lug ends that sticks into the air hose.
4 lug twist on ends. Hose ends came with band clamps, but im going to need a tool to tighten those up, plus im not sure how stong they will be. Band clamps Worm Gear clamps Interlocking u bolt clamps any others? Thanks |
Re: Fittings For Air Compressor Hose
With those large fittings, the barb part is normally long enough that you're supposed to use two band clamps or one large crimp ferrule. If you use band clamps, you alternate the worm drive on the second clamp 180 degrees to the opposite side.
just to double check..
band clamps and worm clamps are 2 different clamps. these are band http://www.campbellfittings.com/pdfs/band.pdf these are u bolts http://www.campbellfittings.com/pdfs/ubolt.pdf these are t bolts http://www.campbellfittings.com/pdfs/tbolt.pdf these are regular bands http://www.campbellfittings.com/pdfs/band.pdf these are worm http://www.campbellfittings.com/pdfs/worm.pdf |
Re: Fittings For Air Compressor Hose |
which would you prefer?
i like the interlocking u bolt clamps.
any places online where i can order these?
I have a local vendor for those (airline hydraulics). Grainger only has up to 1" for the two lug, jackhammer type coupler.
| Gator bite fittings, feed back please | tzzzz216 | Plumbing | 126 | 04-27-2011 11:44 AM |
| Shark Bite fittings | tzzzz216 | Plumbing | 35 | 12-15-2009 10:59 AM |
| determining exact tangent point for stair fittings | troubleseeker | Finish Carpentry | 3 | 04-19-2007 08:05 AM |
| Fair job costing for contractors! | 4thGeneration | Painting & Finish Work | 8 | 11-24-2006 01:09 AM |
| Flexible Black Poly Tube and ABS Fittings? | theworx | Plumbing | 2 | 05-23-2006 12:49 AM |
