Feed Back Please ,water Heater Thermostat
Old 11-10-2006, 11:26 PM   #1
Plumber
tzzzz216's Avatar
Trade: Plumbing
I had a customer call me about their water heater running out of hot water,the heater is only 3 years old. when i got there i felt the water and it was hot , I checked the elements and thermostats upper and lower they were good on the meter , but when I turned the thermostats down to 90 degrees upper and lower only the lower thermostat shut off at 90 degrees then i tried to turn down the upper one at 90 degrees it wouldn't shut off, but then I turned the upper one up to 150 and it shut off and started hammering, with it shutting down at that temp. the water must have been getting that hot for it to shut down at that temp.Right ? , I changed out the thermostat and it shut down at 120 degrees and the water seems to be hotter , than when i first checked it. I guess my question is this do think the same thing that the upper thermostat was reaching 150 degrees for it to shut down at that setting. Thanks in advance.
tzzzz216 is offline
Old 11-10-2006, 11:31 PM   #2
mdshunk's Avatar
Re: Feed Back Please ,water Heater Thermostat
The top thermostat has a contact that will close when it is satisfied and send power to the lower element's thermostat. If the top element's stat had the top element running all the time, the lower element will never run. It would be running on one element (the top one) all the time. I believe you fixed your problem when you changed out that "stuck" top thermostat.
mdshunk is offline
Old 11-10-2006, 11:38 PM   #3
Plumber
tzzzz216's Avatar
Trade: Plumbing
Thanks for the fast feed back on this mdshunk .
tzzzz216 is offline
Old 11-10-2006, 11:43 PM   #4
mdshunk's Avatar
For future reference, or for anyone else who cares, here's a generic wiring diagram for 90% of the electric water heaters out there:
mdshunk is offline
Old 11-11-2006, 02:42 PM   #5
Plumber
tzzzz216's Avatar
Trade: Plumbing
Thanks again mdshunk !!
tzzzz216 is offline
A little feed back... Orlando IR Technology 11 05-11-2006 05:07 PM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
water heater going bad? smitty58 Plumbing 1 01-07-2006 09:10 AM
Bathroom wall heater locofoco Electrical 7 12-21-2005 10:24 PM
New Thermostat for American Standard Supmac HVAC 2 12-05-2005 07:16 PM
