Favorite Gas Water Heater?
Old 03-16-2007, 07:23 PM   #1
rhinoguy's Avatar
Trade: general household repairs
Question
What do you folks like to install when someone's old State water heater dies? I'm interested in a 50 gallon now, usually need 40's. The gas line is there (3/8")and the sweat fittings are easy to get to.
What's the most reliable and easy to repair when it gets old? Opinions of course.
rhinoguy is offline
Old 03-16-2007, 07:25 PM   #2
mdshunk's Avatar
Re: Favorite Gas Water Heater?
A.O. Smith
mdshunk is offline
Old 03-16-2007, 07:53 PM   #3
rhinoguy's Avatar
Unhappy
Originally Posted by mdshunk View Post
A.O. Smith
“A.O. Smith,” “Reliance,” “Apollo,” “State,” or “Maytag”
Ummmm?
This doesn't relate exactly to what I have in mind but: http://www.cpsc.gov/cpscpub/prerel/prhtml06/06002.html
Are the various brand names like Ford, Mercury, Lincoln? All the same company but better products as you spend more?
rhinoguy is offline
Old 03-16-2007, 09:32 PM   #4
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Bradford White
Ron The Plumber is offline
Old 03-16-2007, 10:02 PM   #5
TurdMaster's Avatar
Trade: Mechanical Contractor
State, Rheem, Bradford White, there all the same. I can tell you for sure, G.E. is junk! Stay away from them as I have done 4 in the last 6 months that were less than a year old.
TurdMaster is offline
Old 03-17-2007, 09:39 PM   #6
Squench's Avatar
Trade: Professional Plumber / Amateur Racer
rhino, you want opinions I got 'em!
I am fairly positive, (someone correct me if I'm wrong) GE has the "bulb" safety device, that when shattered, gives way to a spring loaded plate that blocks the oxygen supply. The federal mandate on the sealed combustion chamber has spurned a few different designs, but all subject to failure due to oxygen deprivation, given the right circumstance. I think Rheem, has the perforated sides. When in a laundry room, they will suck up lint and are difficult, if not impossible to clean out. At least Bradford White has a removable screen that will catch all the dust but... I went to service a new Rheem heater that would burn the pilot, but only flame up for a second or two..then extinguish itself. Pilot would almost always burn, but you had to wait a minute or two for it to relight, then poof. Gas supply was fine. Old heater worked 20 years until leakage. Located in laundry room, lint everywhere.
State comes with nipples that are too short, and the plastic "escutcheon" is often raised to the point where you are grabbing threads with the pipe wrench, and the AWC Premier Plus, they go berserk with the spray expandofoam insulation, often to the point where it obstructs the threaded insert. I have to take a knife to them.
Whirlpool stupid left hand thread thermocouple and ANY heater that has a plastic boiler drain! Talk about JUNK!!
gee whiz I went into a rant! sorry about that
I guess what I'm saying is A.O Smith Bradford White
Squench is offline
Gas water heater with timer on it? rhinoguy Plumbing 1 06-10-2010 11:11 AM
Is it safe to drink water from Hot water Heater? robertc65 Plumbing 14 02-04-2007 12:11 PM
Water heater Help tzzzz216 Plumbing 10 11-22-2006 03:30 PM
Expansion tank on water heater Teetorbilt Plumbing 5 04-17-2006 01:53 PM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
