Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Plumbing
Old 07-27-2009, 09:53 PM   #1
ChrWright's Avatar
Trade: Builder/Remodeler
Failed inspection--CSST flexible gas line
I know this has been discussed before, but I thought I'd bring it up again.
I had a kitchen remodel fail an inspection today because of a rule I'd never heard of. I'm curious to know if this is being enforced more and more across the country (or being banned altogether). I've had flexible gas line installed on a number of projects and this is the first time this has ever been brought up by an inspector.
He claimed the new rule is that any flexible gas line must have a minimum 2" clearance from any metal duct work, conduit or electrical line. The reasoning behind the rule being that in the event of a lightning strike, current can arc through the thin wall gas line and cause an explosion. He did not, however, mention any grounding requirement---which as I've researched this more surprises me.
My plumber called in to the local union heads and it's my understanding this is a rule they have only just begun to enforce here in Indy.
http://www.wthr.com/global/story.asp...Type=Printable
Christopher Wright, WrightWorks, LLC
www.WrightWorks.net - Facebook - Christopher Wright, Remodeling Info on Twitter
Indianapolis Remodeling Contractor - Remodeling Photos: Kitchens, Baths, Room Additions, Basements
"Form follows function - that has been misunderstood. Form and function should be one, joined in a spiritual union." -Frank Lloyd Wright
ChrWright is offline   Reply With Quote
Old 07-27-2009, 10:43 PM   #2
Sounds like he's talking about
the new "bonding" requirements.
Everyone seems too sketchy for me,
I'm just going with black pipe til
everyone is telling me the same story.
neolitic is offline   Reply With Quote
The Following User Says Thank You to neolitic For This Useful Post:
skyhook (07-27-2009)
Old 07-27-2009, 10:47 PM   #3
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
I still use mostly black pipe and copper with flare fittings.
I had all the stuff in flex to do a kitchen and chickened out and installed pipe up through the floor, my gas guy was cool with that
silvertree is offline   Reply With Quote
Old 07-28-2009, 10:12 AM   #4
ChrWright's Avatar
A bump to a another thread related to CSST...
http://www.contractortalk.com/f77/cs...details-34546/
I may be switching to hard pipe for the time being as well.
Old 07-28-2009, 11:46 AM   #5
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Ok then, isn't that gas supply on the back of most ranges a flexible tubing like what you are talking about. That is ok but, not for coming through the floor? Hard line through, then to the flex for the range whip? Seems that does not make much sense either.
WarnerConstInc. is offline   Reply With Quote
Old 07-28-2009, 11:47 AM   #6
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
sleeve it in pvc pipe where needed
rbsremodeling is offline   Reply With Quote
Old 07-28-2009, 01:17 PM   #7
ChrWright's Avatar
Sleeving doesn't matter according to my inspector. 2" minimum from any continuous metal, period.
Apparently this was part of 2005 code amendments--but the inspectors in my area have only recently been through CSST training to enforce it.
Old 07-28-2009, 01:43 PM   #8
New code changes or additions always bring problems with them
Paint or stain on hardi plank? Jer Painting & Finish Work 23 01-31-2009 06:05 PM
What Is The List Of Every Line Item Possible For Roof Replacemts From Insurance Cos.? Ed the Roofer Roofing 15 08-31-2008 03:19 AM
What Is The List Of Every Line Item Possible For Siding Jobs From Insurance Cos.? Ed the Roofer Windows, Siding and Doors 0 08-27-2008 07:20 PM
Straight Horizontal Line Speer007 Carpentry 17 12-15-2006 06:26 PM
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 20 04-25-2004 10:38 AM
