Unregistered
Guest
Posts: n/a
External Insulation Wrap For Hot Water Heaters
Does anyone have any feelings on the hot water heater insulation wraps that you can buy to wrap around your hot water heater? Are they any good or even worth the effort? Do they really work? Does it do any good?
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: External Insulation Wrap For Hot Water Heaters
When I had a second hot water heater added to my house I discussed this with the plumber, his answer was to touch the side of the tank, was it hot? He said if I couldn't feel the heat from the hot water inside then the tank was insulated properly and therefore the hot water inside couldn't feel the cold air outside either.
Sounded logical to me. I would like to have everyone of my hot water copper lines wrapped though. |
I would check with the heater company, as some will void the warrenty if it has been insulated.
BJD |
#4 | |
Unregistered
Guest
Posts: n/a
Re: External Insulation Wrap For Hot Water HeatersQuote:
I could understand that and it does make sense. But, what if the coldness on the outside caused the hot water heater to cool down faster and fire up more to keep the desired temperature. You wouldn't feel it by touch. But, you may feel it in your bill. I noticed that my hot water heater fires up more in the winter then it does in the summer |
| Best and Worst Water Heaters | Richard | Electrical | 23 | 10-10-2009 11:35 AM |
| gas dryer next to 3 gas water heaters | fast pasquale | Plumbing | 9 | 05-26-2007 11:28 AM |
| Water heaters and model codes | mdshunk | Plumbing | 9 | 01-16-2007 01:26 PM |
| water pressure with on demand heaters | Vermonster | Plumbing | 2 | 11-11-2006 07:14 AM |
| fastening wire + wrap to foam insulation | mas | Construction | 0 | 07-07-2006 10:39 PM |
