Expansion Tank On Water Heater
Old 04-16-2006, 12:19 PM   #1
Teetorbilt's Avatar
I need to replace my water heater and have noticed that in all of the new construction that they are placing a small (2 gal.) pressure tank on top of the heater. Why?
I'm assuming that it has something to do with backflow preventers and being on city water. I'm on a well and have a big tank out back with all of the rest of the Chernobyl looking junk.
Albert Einstein
Teetorbilt is offline
Old 04-16-2006, 12:49 PM   #2
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Re: Expansion Tank On Water Heater
I believe it works in conjunction with the Temp/press. valve to absorb extra volume and or pressure buildup in the tank. More safety for the homeowner
ron schenker is offline
Old 04-16-2006, 08:08 PM   #3
ATH's Avatar
I installed one recently after my pressure regulator started to leak periodically. Problem solved.
Apparently, after using hot water, the cold water that replaced it would expand as it was heated. The pressure had to go somewhere. We had oreviously noticed a little weeping from the pressure relief valve on the water heater and the toilet fill valve seemed a bit weak.
We replaced both and now the weakest link in the system was the gasket on the pressure regulator.
I verified the problem before installing the tank by putting a gauge on the washer feed. I pegged the needle on the gauge!
Installing a tank was a lot cheaper than replacing the regulator. I'll probably have to do that too, soon. But I got a little more time out of it.
Wayne
Around the House
http://www.MyPowerCouple.com
ATH is offline
Old 04-16-2006, 08:51 PM   #4
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Also if the water heater is used to heat the house too you need an expansion tank
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 04-17-2006, 01:03 PM   #5
Electrical & Plumbing
Atricaudatus's Avatar
Trade: Electrical and Plumbing contracting
You nailed it ATH. Here in NC this is now a code requirement, and it's for exactly that reason. As the water is heated it expands, and the tank gives the system somewhere to expand to without creatng weeps and drips at your TPV or elsewhere.
-Rhett
Licensed electrician and plumber
Atricaudatus is offline
Old 04-17-2006, 01:53 PM   #6
Plumbing/Mechanical Insp.
Moscow's Avatar
Trade: plumbing/mechanical/building inspector
The real reason for an exspantion tank on hot water tank, is if you have a close loop system with a check valve or a backflow perventer. If you don't have both or one of the devises you will not have anyproblem.
However in some citys they have check vavles on the meters, then you have a close loop in your system and you will need a expantion tank.
Good Luck
Justin
Moscow is offline
Is it safe to drink water from Hot water Heater? robertc65 Plumbing 14 02-04-2007 12:11 PM
Thermal Expansion Via Iraq jicoll2000 Plumbing 12 12-16-2006 04:05 PM
Water heater Help tzzzz216 Plumbing 10 11-22-2006 03:30 PM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
