Eternal Trap?
Old 02-21-2008, 08:50 PM   #1
Eternal Trap?
I've never seen this one before
in residential.
1¼" chrome lav trap sweated into
a 1¼" to 1½" male adapter, screwed into
a 1½" brass el, inside the drywall,
behind the vanity.
How? More to the point, why?
neolitic is offline
Old 02-21-2008, 08:55 PM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Eternal Trap?
See it all the time here. No surprise. Old timers, it don't happen today.
Ron The Plumber is offline
Old 02-21-2008, 08:58 PM   #3
Re: Eternal Trap?
This one was from 1969.
Good thing they decided on the
remodel.
I crushed the trap with my hand.
neolitic is offline
Old 02-21-2008, 08:59 PM   #4
Pro Plumber
Trade: Plumber
Re: Eternal Trap?
I just cut them out if they don't unscrew, then use a male adaptor in it's place and plastic trap after the fact.
Old 02-21-2008, 09:04 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Eternal Trap?
in residential.
behind the vanity.
That is called a solder bushing, back before the seventies in most parts of the country you could not have a slip connection after the outlet side of the trap, solder bushings were an easy way to make the connection between the drainage fitting and the tubular brass. 50/50 solder made it so that a minimal amount of heat was needed to solder the joint.
KillerToiletSpider is offline
Old 02-21-2008, 10:37 PM   #6
Re: Eternal Trap?
Guess the guy was from Chicago,
never seen that here, and I've
torn out plenty of 60's and earlier
bathrooms.
They were even using slip-joints
here in the 20's.
Maybe the 50/50 makes it easier...
couldn't believe not a scorch on the
drywall or even the cheesey masonite
vanity back!
neolitic is offline
Old 02-24-2008, 03:36 PM   #7
masterk's Avatar
Trade: Plumbing
Re: Eternal Trap?
There here, I replace them all the time.
masterk is offline
is the underground pipe layout correct? stoneweed1 Plumbing 26 02-02-2008 05:14 PM
Help-sand Trap Slow Drain PARA1 Plumbing 2 12-31-2007 08:53 PM
P trap placement Jesse Benson Plumbing 7 09-29-2007 01:21 PM
Coil height for condensate drain trap davidchomes HVAC 10 09-10-2007 10:36 PM
Dumb trap Davidw53 Plumbing 2 02-16-2004 08:40 PM
