View Poll Results: What type of Material do you use most of the job? Check all that applies
ABS 11 50.00%
PVC 11 50.00%
CPVC 1 4.55%
Copper 11 50.00%
Pex 10 45.45%
Multiple Choice Poll. Voters: 22. You may not vote on this poll
DWV Material
Old 09-15-2007, 12:39 PM   #1
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
DWV Material
Poll on what material you use on the job DWV and Water Distro.
Ron The Plumber is offline
Old 09-15-2007, 02:07 PM   #2
Grumpyplumber's Avatar
Trade: Plumber
Re: DWV Material
Personally I'd rather use ABS over PVC for residential, but suppliers here either don't carry it, or have limited fittings.
The West coast uses nothing but.
If i really had my choice, CI/copper for DWV, copper for supply.
Bid those materials against other contractors and you'll stay home alot.
Grumpyplumber is offline
Old 09-15-2007, 02:21 PM   #3
mickeyco's Avatar
Trade: Squirrel Handler
Re: DWV Material
Where's the cast iron option? I still see it being used.
mickeyco is offline
Old 09-15-2007, 03:45 PM   #4
Trade: Plumber
Re: DWV Material
On commercial, high end residential or where code forces it to be used.
Usually residential GC's go for lower prices, sad but true.
Now new residential plumbers are being slowly pushed into running garden hose (PEX) on many houses.
Old 09-16-2007, 09:15 AM   #5
Vabuilder's Avatar
Re: DWV Material
I came up using PVC for DWV and copper for water Dist., and will never use the "spaghetti pipe" or AKA "pex". we use cast iron for the vertical drops in two stories to keep the sound down.
A gun in the hand is better than a Cop on the phone !!!
Vabuilder is offline
Old 09-16-2007, 09:46 AM   #6
pyroracing85's Avatar
Trade: HVAC
Re: DWV Material
If you guys were building a house with no cost restraints would you use cast iron piping?
pyroracing85 is offline
Old 09-16-2007, 10:58 AM   #7
Pro Plumber
Trade: Plumber
Re: DWV Material
Ok who is using cpvc and why?
Old 09-16-2007, 03:34 PM   #8
Trade: Plumber
Re: DWV Material
"Father, forgive me for I have sinned."
I have Ron, when the water has been bad enough to know copper wouldn't last long.
I worked for a shop the regularly used PEX, but I hated the stuff, the only alternative that has a relatively proven track record is CPVC.
With PEX you have two main alternatives, I know I'm not educating anyone here, but there's the expansion type that is stretched then fitted over the fitting which has a reduced id.
Then there's the crimps and I ain't goin' there!
Both require a tool thats both expensive and cumbersome to use.
I have seen recent buzz of potential lawsuits on the crimps with PEX.
As far as I'm concerned, I'd just as soon avoid anything that relies on a mechanical connection to make a seal on high pressure water like Sharkbite, Crimps, Expansion, Propress...etc.
If I can't bid on copper and be competitive, I bid CPVC or no bid.
Solvent weld just gives me a warmer, fuzzier feeling.
I'd be freaking delighted if the plumbing powers that be made both illegal, but unfortunately you have to be able to bid competitively, and copper is too much.
Old 09-16-2007, 03:37 PM   #9
Trade: Plumber
Re: DWV Material
Where the heck is Killer in all this?...his thoughts on this specific topic would be very interesting.
Old 09-16-2007, 03:55 PM   #10
The Grand Wazoo
KillerToiletSpider's Avatar
Re: DWV Material
Most of our jobs are in high rises, all copper waste, vent, and water.
I have done some single family homes with NHCI waste, and pvc vents, they were water piped in copper.
KillerToiletSpider is offline
Old 09-16-2007, 04:18 PM   #11
Trade: Plumber
Re: DWV Material
Killer, we know that.
I was personally hoping to hear your thoughts on what I'd posted regarding pricing/competition vs quality.
Old 09-16-2007, 05:01 PM   #12
The Grand Wazoo
Re: DWV Material
I don't bid work on price really, and I choose material based on installation cost and end user quality over price. On single family homes where we can use PVC, but we don't because it's loud, and when the end user is living there, they hear it every time water is used. For water pipe, we could use CPVC, but in order to deliver a quality and to code job, it has to be continuously supported, with a hanger every foot, but I can hang copper with a hanger every 8 feet, that makes copper a faster job to install. PEX isn't approved here yet, but even when it is we won't use it, we might consider it when it has been around for 30 years and proven it is a viable maintenance free system, to me it looks like crap and a leak waiting to happen. The expansion/contraction rate of plastic combined with a mechanical joining process strikes me as a dumb idea, especially after the polybutylene fiasco from about 15 years ago.
Old 09-16-2007, 05:03 PM   #13
The Grand Wazoo
Re: DWV Material
I don't do jobs with cost restraints, and I plumbed my house with cast iron waste and pvc vents.
deck material smarks General Discussion 12 12-12-2007 03:59 PM
Expansion material needed or not? davidchomes Concrete & Paving 6 09-08-2007 01:17 AM
Material choice for fascia. kclapper Windows, Siding and Doors 5 07-31-2007 11:14 PM
Question regarding surplus electrical material solcam Electrical 2 07-25-2006 06:31 PM
Paying for material 6stringmason Masonry 24 03-30-2006 09:10 AM
