Trade: electrician
Drain Pipe Holes Up Or Down?
when installin PVC drain pipe with hole what is the correct method?
Re: Drain Pipe Holes Up Or Down?
For the most part holes down, although sometimes I'll rotate the pipe a little clockwise.
Vagitarian
Holes down
Trade: Masonry consultant
Holes down to collect water.
No holes to carry it away. One hole at the end to let out the water.
Dick Engineer, designer and consultant recently active domestically and internationally on construction and design in about 35 countries. |
Trade: Plumber
Re: Drain Pipe Holes Up Or Down? |
Trade: Renovations
It's a perimeter drain, it's there to pick up water around the building and get rid of it, so... holes down. Rain leaders here have to be in a different pipe, with no holes. (Except at the ends
Holes down, and if you are also running rain drainage (gutters and downspouts) always run in a separate pipe with no holes.
Never tie the two together. Never. |
Trade: Renovations
As soon as you're away (downstream) from the building you can tie them together in solid pipe.
Trade: Plumber
ahhhh...ya mean a french drain...got it...got it
#10 | |
Re: Drain Pipe Holes Up Or Down?Quote:
I would tend to disagree with tying them together for the following reason. In the event that the drain gets clogged for whatever reason downstream of were the join, the water from the rain drains will flow back up to the foundation drain and possibly cause flooding of the basement. All it would take is some animal to decide the pipe is a cozy place to start a family, or the pipe is collapsed somehow...then the next thunder storm causes a backup. We always run parallel pipes, keeping them separate, the trench is already there and the added expense of the additional pipe is cheap insurance.
| Drain Pipe | denick | Excavation & Site Work | 18 | 07-12-2009 04:41 PM |
| black drain pipe?? | pauls painting | Plumbing | 5 | 01-08-2007 11:29 AM |
| Copper Pipe, Pin Holes , is it happening by you?? | tzzzz216 | Plumbing | 16 | 11-18-2006 08:48 PM |
| Ace Duraflow vs PVC Drain Line Repiping to Replace Cast Iron Drain Pipe | TDELC | Plumbing | 0 | 10-16-2006 03:31 PM |
| How to rock around drain pipe that stick out 1/4in from stud? | ruskent | Drywall | 11 | 04-27-2006 12:02 AM |
