Drain For Ice Machine
Old 06-24-2007, 05:17 AM   #1
Plumber
tzzzz216's Avatar
Trade: Plumbing
Question
A customer called me out to take a look at her ice machine at a convenient store today , the drain line for the ice machine is dumping out into the grass area but before that its leaking on the sidewalk for which the health inspector wrote her up on water on the sidewalk , I looked in the store for a floor drain to pipe as an indirect waste ( BY Code ) but there wasn't one to be found , right next to the ice machine is a hand sink which is also piped to the outside strapped to the wall going into the septic tank ,I guess thats why these 2 items were piped to the outside wall , the only options i see is to repair the leak and leave it going into the grass area and bug proof the end of it or cut a fitting into the sanitary line and turning up with a trap/hub drain, the only problem with that is the customers dumping everything into the trap , Thanks in advance .
tzzzz216 is offline
Old 06-24-2007, 02:12 PM   #2
mdshunk's Avatar
Re: Drain For Ice Machine
Does this ice machine have a water cooled condenser? (Ie... lots and lots of water down the drain?). If not, you could just pipe the drain into a condensate pump and pump it someplace more desirable.
mdshunk is offline
Old 06-24-2007, 03:43 PM   #3
Plumber
tzzzz216's Avatar
Trade: Plumbing
Thanks md , its not water cooled , the I forgot about using a condensate pump great idea !!!
tzzzz216 is offline
Old 06-24-2007, 03:48 PM   #4
mdshunk's Avatar
I kinda thought so. If you don't have a water cooled condenser, the only drain water you have is melt water from the holding bin. Shold be easily accomodated by a condensate pump if you have enough height between the bin drain and the pump tank inlet.
mdshunk is offline
Old 06-25-2007, 01:34 AM   #5
Plumber
tzzzz216's Avatar
Trade: Plumbing
Thanks again md !!
tzzzz216 is offline
Milling Machine Techniques BlackGold Concrete & Paving 1 09-08-2007 04:17 PM
Drain Flies robertc65 Plumbing 6 07-29-2007 01:05 AM
Condensate drain question airwick HVAC 6 07-23-2007 07:48 PM
General purpose machine Vermaraj Excavation & Site Work 10 03-21-2007 01:09 PM
Tub install and drain in slab Mpeters Plumbing 2 03-04-2007 05:43 PM
