Drain Flies...
Old 02-12-2017, 10:56 PM   #1
perkins25's Avatar
Trade: General
Rewards Points: 136
Drain Flies...
Thought I would ask this here. Hope it is okay in this section. Not really all that knowledgeable with pluming pests but I have seemed to run into an issue. I have drain flies showing up in two areas of my house; the first floor bathroom and the basement. Not sure where they are coming in. I have cleaned out all the drains and they were not around for a good 2 weeks but returned. Anyone have experience with ridding them?
Perkins Preferred Roofing and Construction
45 Cascade Springs Place,
The Woodlands, Texas 77381
http://www.perkinspreferredroofing.com
perkins25 is offline
Old 02-13-2017, 06:25 AM   #2
rrk's Avatar
Rewards Points: 1,884
Re: Drain Flies...
A customer of mine had them last year, I cannot remember the name of them but they were really small, the size of fleas or smaller. Took a few months to get rid of them. Exterminator said they came in from the ground outside and would congregate at sink and shower drains. If it is wet or damp outside they stay outside. He sprayed outside right around the house, and she sprayed the drains constantly with some environmentally safe stuff.
Still took forever to get rid of them
rrk is online now
Old 02-13-2017, 08:16 AM   #3
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 20
Re: Drain Flies...
Drain flies have the big wings compared to their body size. They could be coming from a drain trap, a crack in a sewer line in a slab, or a drain vent that has come loose in a wall. You could try putting a clear cup smeared with something sticky over suspect drains and see if you catch anything.
P42003 is offline
The Following User Says Thank You to P42003 For This Useful Post:
MarkJames (02-13-2017)
Old 02-13-2017, 08:40 AM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,937
Re: Drain Flies...
It could be that an unused drain P-trap has dried out, as well. That's my first bet.
Pour some water down each of the unused drains to get some water into the traps. Unused basement floor drains, lavatories and tubs, etc. Some old laundry rooms may have a floor drain that's hiding under an appliance (not to be confused with drain pans with drain..just leave those alone).
After filling an old trap, a drop or two of oil (eg. mineral oil) will slow the evaporation for next time.
MarkJames is online now
Old 02-13-2017, 12:46 PM   #5
prcroofing's Avatar
Trade: Commercial Roofing
Rewards Points: 122
Re: Drain Flies...
You should consider checking around the washing machine. A family friend had an issue with these bugs a few years back and after basically tearing down all the plumbing he finally realized they were in the washer hook-ups. They need heat to lay eggs and breed.
PRC Roofing and Sheet Metal
3714 Osage St.
Houston, TX 77063
http://commercialroofinghoustontx.com/
prcroofing is offline
Old 02-13-2017, 12:55 PM   #6
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,980
Re: Drain Flies...
Same in my shower. Go to Amazon search Drain Flies. There are a couple liquid products that have good reviews....DX 500 or something.
Also get a drain brush for about $12. You have to disrupt where the nest. Use the brush to push everything down a bit.
Steve
We Fix Houses is online now
Old 02-13-2017, 06:35 PM   #7
ACManHouston's Avatar
Trade: HVAC
Rewards Points: 124
Re: Drain Flies...
This is your best bet and I am assuming you will see that after you google a bit on the flies. They don't harm anything but they can get out of control fast. You have to destroy the feeding source and destroys the nests. It can take weeks, sometimes months if the problem is big enough. Just stick with a plan till the pests are gone.
AC Man Houston
1539 S Mason Rd.
Katy, TX 77450
http://www.acmanhouston.com
ACManHouston is offline
Old 02-13-2017, 07:17 PM   #8
Business Owner
P42003's Avatar
Rewards Points: 20
Re: Drain Flies...
And to reiterate, make sure you are correct on the identification of the fly, i.e drain flies vs phorid flies, etc.
P42003 is offline
Old 02-14-2017, 05:22 AM   #9
builditguy's Avatar
Rewards Points: 406
Re: Drain Flies...
I had something similar. I think. I called them Buffalo knats. They were around my kitchen sink drain. Showed up first of the summer and stayed all summer. Searched the web and tried everything. I think I made a dent in them, but nothing really worked. At the beginning of fall, they disappeared.
Next summer they were back. Fought them hard again. Cleaned everything and always made sure food was cleaned up. Every cleaner I could think of, nothing really worked. End of summer they disappeared.
Never came back.
I did read about a trap for them. I made one out of tupperware with an onion for bait. I thought it worked really well. Caught more than I ever saw. Finally my wife made me stop. She decided I wasn't trapping them, I was breeding them.
I don't know about that, but I was sick of messing with that trap anyway.
builditguy is online now
Old 08-16-2017, 04:30 AM   #10
HotDawg's Avatar
Trade: Plumber
Rewards Points: 30
Re: Drain Flies...
You need to put some strong ass bleach where they've been coming from. Make sure nothing can survive.
Traps are a good shout, but it doesn't really stop the problem as they still may come back in the future. If you go on amazon or to a supermarket/hardware store they should sell something appropriate.
Mr D
Work as a Manchester Plumber
HotDawg is offline
Old 09-08-2017, 02:27 AM   #11
Jerry L. Garcia's Avatar
Trade: Denver Bath & Kitchen Remodel Group
Rewards Points: 30
Re: Drain Flies...
Drain flies are known for being the big wings as compared to their body size. They are known for helping coming from a drain trap, also crack them into a sewer line under a slab.
Also, it should be known for trying helping one putting a clear cup smeared with something that is sticky over the suspect drains and also see if you are catching something.
Jerry L. Garcia is offline
Old 09-08-2017, 06:35 AM   #12
TimNJ's Avatar
Rewards Points: 2,690
Re: Drain Flies...
Call them sewer flies here.
This year I have been plagued by them. They are outside and get in when opening the door or a window.
You can pour stuff down your traps but if you go up on your roof you will see they are in the vent pipe or if you open a cleanout in your sewer line they will be in there too.
I am thinking I should have my septic tank pumped.
TimNJ is online now
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
Bathroom sink strainer drain issue with venting stanfordconst Plumbing 1 05-19-2011 06:06 PM
Gurgeling sound in Tub Drain???? painter213 Plumbing 6 06-22-2010 04:11 PM
Drain Flies Again robertc65 Plumbing 5 07-08-2009 11:18 PM
Drain Flies robertc65 Plumbing 6 07-29-2007 12:05 AM
