Does This Fitting Exist??
Old 08-05-2009, 08:08 PM   #1
builditright's Avatar
Trade: Field Super
Men,
Has anyone ever used or seen a " 3/4"copper x 3/4" Male IPS tapped 90 degree elbow?? The tapping is for an air bleed vent on a hot water loop heating system. I've seen the common 3/4" tapped cooper elbow and a 3/4" copper x male IPS elbow but never one with the tapping.
Thanks
builditright is offline
Old 08-05-2009, 08:29 PM   #2
BCConstruction's Avatar
Trade: Construction
Re: Does This Fitting Exist??
Originally Posted by builditright View Post
Men,
Thanks
Could you not knock one up with other fittings?
BCConstruction is online now
Old 08-06-2009, 01:00 AM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
What are you talking about, tapped, tapping, these are not your common fitting words I ever heard for plumbing fitting.
Then there is knock one up, what is that all about?
Ron The Plumber is offline
The Following User Says Thank You to Ron The Plumber For This Useful Post:
skyhook (08-06-2009)
Old 08-06-2009, 01:30 AM   #4
mics_54's Avatar
Trade: contractor
don't base board bleeders come with an elbow?
mics_54 is offline
Old 08-06-2009, 07:46 AM   #5
Trade: Construction
By tapped he means female internal thread. As in Tap or Die thread. So that he can screw a air bleed valve into it. thats how im pictureing it. I dont do a lot of black iron work so this fitting is new to me. Dont sound like the kind of heating system vents i ever seen before. The type i normally use are AAV's.
By knock one up i mean if you can find 2 fittings that will do the same thing when joined together. I heard many different terms for things since moving from the UK so im used to some different jargon.
Old 08-06-2009, 09:48 AM   #6
Trade: Field Super
Found it. Elkart products carries it. It is not stocked in many supply houses since its an "i F$@!ed up on the roughing" fitting.
Thanks
Old 08-06-2009, 12:18 PM   #7
Trade: Construction
post a pic up of the fitting. im curious to know what it looks like compaired to how i pictured it.
Old 08-06-2009, 08:46 PM   #8
DetailHandyman's Avatar
Trade: Professional Handyman
Well, if you put a male thread with a female thread...
"cobble together"
"redneck engineered" (yeah, I avoided the obvious one so as not to offend)
The cat box ain't gonna clean itself.
DetailHandyman is offline
Old 08-07-2009, 01:15 AM   #9
MZ-HANDYMAN's Avatar
Trade: Custom Home Remodeling 30+ yrs
He meant "MOCK UP" Make one out of other parts.
MZ-HANDYMAN is offline
no-hum multi-fan speed control? Does it EXIST? ruger9 Electrical 45 10-09-2010 05:41 PM
Odd angle fitting from a 45 elbow Spooker Welding & Steel Trades 2 04-18-2010 08:20 AM
hand rail fitting cutting tips beerdog Carpentry Picture Post 8 11-06-2009 11:33 PM
Fitting big tires on truck BattleRidge Vehicles 22 03-27-2009 06:12 PM
Compression T Fitting vs. Re-Threadding Galvanized Water Main mtbmac Plumbing 47 09-14-2008 12:33 AM
