DN Construction
Trade: Construction
Dishwasher's Own Sewer Line?
I have come across a client that wants their dishwasher not near their sink due to a small kitchen in a condo. If we were to move the dishwasher to the other side of the kitchen we will gain about 9' of counter top. My question is can I install a trap and tie into the sewer line on the other side of the kitchen. This will work out perfectly because the sewer line runs this way. I was thinking of using a icemaker in-wall box and converting over to a hose barb. That way I can hose clamp the drain line right into it? What I have read is the dish washer has a drain pump in it so logically it should work. Also there is a vent right on the other side of where I would put my trap in to connect to the sewer line. Let me know what you guys think. This is the only plumbing that needs to be done for this client so thats the reason why I didn't call my plumber, and he is not the nicest guy, so I didn't want to bother him with this question. Thanks in advance. Also I am in the market for a new local plumber in the pt pleasant, bricktown area of jersey.
Thanks Dave |
#2 | |
Pompass Ass
Re: Dishwasher's Own Sewer Line?Quote:
DavidC
Check your local regs. We are allowed to run up to 10' of pipe without a license here. Otherwise, as bwalley said. The air gap is very important.
Good Luck Dave
www.CookContractingLLC.com |
Thom
With the information provided no one can answer accurately. You will need to deal with a trap, a vent, properly graded pipe, proper fittings, an air gap, and probably more. Fittings that look alike to most people are often different. The orientation of the pipe will determine whether you need a sanitary tee or a combination Y & 1/8 bend. to most people these are the same fitting but they work very differently. This doesn't take a licensed plumber, merely a person who knows everything needed to be a licensed plumber.
| The Following User Says Thank You to thom For This Useful Post: | griz (01-15-2010) |
Trade: Construction
I keep seeing these air gap things in lowes but never paid much attention to them. I used to install appliances in the UK and installed thousands of dishwashers and never once had to install one of these air gap gadgets! They also never had vents either but never had issues with them pumping out.
Trade: Renovator
The most common cheat to get around the air gap requirement is a high loop with the discharge hose.
Check out Ridgid's forum. The plumbing expertise on that site can't be matched. They'll discourage a GC from doing plumbing, but they should be able to recommend a good licensed plumber in your area. |
#7 | |
Trade: Construction
Yep thats all we used to do. The machines even come with a u bend that holds the pipe in that shape. Funny why they say you need them over here! The drains are no different. |
Trade: Kitchen and bath design+remodel
Talking to my plumber about that last week and he said that in Oregon it isn't against code not to have an airgap.
Don't know if thats true but do know DW's will work without them |
Pro Plumber
Trade: Plumber
I don't normally come to this site anymore, but since you are talking about Oregon Code, an airgap is not required here.
| Shingles Nailed Above Nail Line.. Help!! | Unregistered | Roofing | 24 | 04-20-2011 09:14 PM |
| Heating detached garage - gas supply line question | jarvo807 | HVAC | 11 | 06-14-2009 12:10 PM |
| 600' Water Line | Knighton | Plumbing | 4 | 05-04-2009 10:54 PM |
| Sewer repairs suck..... | Williams Ex Co | Excavation & Site Work Picture Post | 10 | 03-30-2009 12:38 AM |
| Best way to cut clay sewer tile? | Williams Ex Co | Plumbing | 8 | 12-07-2008 04:50 PM |
