Direct Vent Vs Power Vent Water Heater - Plumbing - Contractor Talk
Old 09-11-2018, 07:39 AM   #1
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,918
Given the choice between the two, which would you chose? Must go through rim joist. Tankless is a negative. Water heater will be in basement against foundation wall.
Half of all people are below average.
Golden view is online now
Old 09-11-2018, 08:46 AM   #2
General Contractor
greg24k's Avatar
Rewards Points: 7,552
Re: Direct Vent Vs Power Vent Water Heater
I have a power vent in my house and I remember reading it someplace that the main difference is between the 2 is that the power vent removes combustion gases from the atmosphere using a fan and chimney vent releases gases into the outdoor atmosphere via the chimney.
Another good benefit of having a power vent is that you can install your water heater anywhere in the house if chimney access is not available.
The only downside that I see is the cost, since its using electric and if the power is out and you have no generator you be without the hot water in the shower.
greg24k is offline
Old 09-11-2018, 07:30 PM   #3
Talking Head
EthanB's Avatar
Rewards Points: 162
Additionally sometimes a power vent is a little loud if it's right under a bedroom or living room and sometimes a chimney vent isn't a good option if it's not properly lined as the gasses will deteriorate a masonry chimney, iirc.
Planer.....
EthanB is offline
Old 09-11-2018, 08:25 PM   #4
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 5,470
https://haleymechanical.com/blog/dif...water-heaters/
Big Johnson is offline
Old 09-11-2018, 09:05 PM   #5
edward trowelhands
Trade: Diplomat
No chimney, I took it out. I have access to direct vent that uses a non powered concentric vent through the wall. Similar cost to power vent. Close to $1000, vs $400 or so for a natural draft chimney vent.
Old 09-11-2018, 09:06 PM   #6
edward trowelhands
Trade: Diplomat
Example: https://www.bradfordwhite.com/direct-vent-gas-models
Old 09-12-2018, 06:53 AM   #7
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 134
A true direct vent with combustion air pulled from the outside via pipe wins hands down - better efficiency, no chance of back drafting, etc... The only thing to watch out for is the condensate - where is it going, etc...
As for power vents - one with a metal exhaust or pvc - pvc same issue as above, metal you need to make sure it doesn't form in the liner but then you are also looking at a larger hole so that would probably rule out that type of model
SLSTech is online now
Water heater vent - run outside of gutter? GoodLJohnny HVAC 2 03-23-2018 07:25 PM
control on electric water heater burnt up Rio Plumbing 8 02-16-2018 09:24 AM
Water heater - on demand or tanked? G.C. Plumbing 2 09-06-2010 06:49 PM
