Delta Pop-Up Grief!
Got a double vanity with all brass
Delta pop-ups (RP26533 if it matters). I've tightened them til it's scary, and they both still leak down the threads below the rubber gasket. This isn't my first rodeo, but this is the first time I've had this problem. The bowls are cast something or other, and they are dead flat on the bottom where the drain hole is...not at all "concave". It seems like the shape of the hole is pulling the top of the gasket open as the nut tightens. I'm thinking of trying a smaller "repair gasket" on top of the one supplied with the faucets, out of desperation. Partner wants to slather the threads with silicone! Any one got any tricks or ideas? Can't get my plumber out til Friday, and I really need to get this solved so that I can pull a much needed draw tomorrow.
Pro Plumber
Trade: Plumber
Re: Delta Pop-Up Grief!
Slop some pipe dope on the gasket tighten and see if that stops it.
#3 | |
Re: Delta Pop-Up Grief!Quote:
Does this crap come up all the time? Or have I just been lucky all these years?
Pro serviceman
Trade: Plumbing service/repair
Teflon tape the daylights out of the threads and dope up the gasket with Rectorseal. This has been an ongoing problem over the years with "square cut" sink outlets. The taper in the outlet isn't there to force the gasket tight against the PO threads. Make your own seal at that point. Silicone works too. Let it dry.
Pro Plumber
Trade: Plumber
I always dope the gasket, also make sure you did not leave out the friction ring.
Delta pop-ups are known leakers, it's a hit and miss thing. Last edited by Ron The Plumber; 03-30-2008 at 06:40 PM. |
The Grand Wazoo
If the pop ups are chrome throw them out and install Gerber 43-973 pop-ups.
Delta drains are known for leaking like a sieve, they are worse than Danze or Water Works drains, which is why we stock the Gerbers at our shop.
#7 | |
after all these years... never came up before, and this is Delta country! Thanks again.
#8 | |
They have one with a brushed SS flange? Edit: Looks like chrome only. Wonder if the Delta flange would thread in there?
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 03-30-2008 at 06:55 PM. |
Pro Plumber
Trade: Plumber
I mentioned this trick in the Tricks of the Trade thread.
http://www.contractortalk.com/showth...943#post345943 |
#10 | |
I did try a "search" before I posted but my batting average is pretty low with that.... I never seem to guess the secret word! ![]() "Pop" and "Up" are apparently to short.
The Grand Wazoo
They make decorative finish faucets, but I would have to call the rep to get just a pop up, they are based in Delphi Indiana, the local plumbing supply house should be able to help.
#12 | |
I think I'll take one of the flanges to the supply and see if they work. Every time the partner goes weak kneed and lets the HO supply stuff I wind up in one of these messes!
Trade: Plumbing
The threads are machine threads so I always put a little silcone on the threads and the washer. Never have a problem anymore, this is now a standard process.
Trade: Plumbing
We had a similar problem But the sink wasn't thick enough. The rubber ring wouldn't seal because we ran out of threads we tried 3 metal washers first it didn't work so what we did was installed 2 rubber washers and tighten the piss out of it. after that it didn't leak an more.
Have A Blessed Day! |
#15 | |
It's some kind of cast china-like stuff. The bottom has no "concavity" to it, and inside the bowl where the flange sits it's to deeply concave for the flange to really conform. I'm afraid to much torque and the stainless flange will just punch through. ....double bowl factory underhung on cultured granite top.... not one I want to crack just now!
Moderator
I find that using a small rope of putty on the gasket will also get it to seal. I use Rectorseal T+2 or #5 on the threads before assembly. If its a cultured product, then I would use the T+2.
#17 | |
or other, it feels like un-glazed china. I'd call it a bisque finish. Pardon my ignorance, but how is the T+2 different to the Oatey teflon dope? I've only used Rectorseal on gas (#5?).
#18 |
Pro Plumber
Trade: Plumber
Don't worry about those pipe dope numbers, just get some type of pipe dope, and slop it on, or silicone, they will all do the job and get it to seal. I use megaloc pipe dope.
#19 | |
![]() I'd never get in a fight between Snoopy and an armed cat! ![]()
#20 |
Trade: plumbing
This is interesting because although it's been several years since I consistently installed Delta products, I don't remember the pop-ups having this problem nor do I find them in this condition in homes that have Delta (which seems to be virtually every home around here). I do not care for Delta for other reasons but the king of crappy pop-up assembles has got to be Price Pfister. When ho's drag this stuff home and then call me to install it I have to tell them we use a different pop-up or we can't install it. About 1/2 the time we end up selling them another faucet with a decent pop-up and if not, we charge them extra for the extra time it will take to tweak that plastic pop-up at least until we can get out the door (we have sternly warned them that it will leak sooner or later before we ever touch it). If it isn't obvious already we give NO WARRANTY.
| 3-phase, 3-wire delta service w/ grounded conductor | Mark Twenhafel | NEC Discussion | 3 | 12-06-2009 11:23 PM |
| Delta Brizo, how much harder to install? | orson | Plumbing | 1 | 03-24-2008 02:56 PM |
| Tile Saw Delta D24000 | Oregon_Rob | Tools & Equipment | 2 | 03-04-2007 07:27 AM |
| Understanding Delta | JamesNLA | Electrical | 19 | 01-29-2007 06:21 PM |
| delta miter saw | behrco | Contractor Swap | 0 | 01-19-2007 12:24 AM |
