Cutting Cast Iron In Crawlspace
Old 01-23-2008, 08:49 PM   #1
PacNWStructures's Avatar
Trade: Framing, remodeling, new construction
Looking for tips on how others have cut cast iron in a tight crawlspace. I've done 4 or 5 all with a sawzall with "cast iron" blades which always takes about 2 or 3 blades per 4" waste and a good half hour. I'm wondering if there is any easier way that might save a little time on my elbows and back.
PacNWStructures is offline
Old 01-23-2008, 08:51 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Re: Cutting Cast Iron In Crawlspace
A deep cut Porta-Band zips through it like nothing.
KillerToiletSpider is offline
Old 01-23-2008, 08:57 PM   #3
Snap cutter is even better,
IMHO
neolitic is offline
Old 01-23-2008, 08:59 PM   #4
The Grand Wazoo
IMHO
If it is cracked or thin on top it will just crush.
Old 01-23-2008, 09:03 PM   #5
smellslike$tome's Avatar
Trade: plumbing
Why aren't you using snap cutters (mini). I've yet to find a situation where they wouldn't fit even in between joists. Oh wow this just made me think of something I like about Home Depot! I bought my snap cutters from their tool rental about 5 years ago for $80.
Looking For A Birmingham Plumber The Best Plumbing in Alabama
smellslike$tome is offline
Old 01-23-2008, 09:05 PM   #6
Trade: plumbing
I've never crushed ci that was out of the ground.
Old 01-23-2008, 09:11 PM   #7
The Grand Wazoo
How much suspended cast have you cut that is on septic? Sulfur Dioxide gas from the septic tank has a tendency to eat the top of cast iron pipe that is installed horizontally.
Old 01-23-2008, 09:19 PM   #8
Trade: plumbing
Not much. I have however, a couple of times, encountered horizontal ci in crawl spaces that were "rotten" for lack of a better term. There was no cutting involved though because as soon as you touched them they fell apart.
I never really knew what might cause this and it's only been a couple of times. Seems like neither system was on septic though, but I'm not certain about that.
Old 01-23-2008, 09:26 PM   #9
The Grand Wazoo
It may have been on one when it was built.
Now you know what causes it though.
Old 01-23-2008, 09:32 PM   #10
Trade: plumbing
Yeah, you could be right. I replaced 60' of sewer last September. When we got about 15' from the house we dug right into the top of the original septic tank. I just about had a stroke for a minute because as far as we knew there was not supposed to be a septic and we had just caved the top of it in. It was old and not in use though. No one had filled it in when they converted to city sewer like they were supposed to though so the lid went crashing down. Scared me for a minute until we figured out what was going on.
Old 01-23-2008, 09:54 PM   #11
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Don't cut at a high speed, the trick behind cutting with blades is slow speed and good constant pressure, cast blades are not needed if you just slow the speed down. The faster you try and cut on cast the faster you fry the cutting teeth. It's an art.
Ron The Plumber is offline
Old 01-23-2008, 09:56 PM   #12
The Grand Wazoo
Porta-band still works better.
Old 01-23-2008, 09:58 PM   #13
Pro Plumber
Trade: Plumber
If one has one, I don't have one myself, so I snap them 90% of the time.
Old 01-23-2008, 10:15 PM   #14
masterk's Avatar
Trade: Plumbing
4 1/2 angle grinder with 1/8 thick cut off wheels.
masterk is offline
Old 01-23-2008, 10:17 PM   #15
Pro Plumber
Trade: Plumber
Cutting torch.
Old 01-23-2008, 10:19 PM   #16
The Grand Wazoo
Hard to use in a crawl if the top of the pipe is close to the underside of the floor though.
Old 01-23-2008, 10:20 PM   #17
Tin Cup's Avatar
Trade: Repair & Restoration Contractor and Specialty Graphics/Sign Installer
great point. mostly true with drill bits also. sloooowwww.
Tin Cup
Tin Cup is offline
Old 01-23-2008, 10:21 PM   #18
The Grand Wazoo
Cutting torch.
You'd have to use a plasma cutter, the tar coating would clog the tip of a torch in no time flat.
Old 01-23-2008, 10:23 PM   #19
Pro Plumber
Trade: Plumber
Was just kidding about that, that just crazy.
Old 01-23-2008, 10:24 PM   #20
Trade: plumbing
shaped c4!
Cast iron undermount sinks skidmark845 Plumbing 2 08-12-2007 03:41 PM
cast iron welding ibsocal Welding & Steel Trades 2 06-23-2007 12:42 AM
PVC to Cast Iron Under Concrete dzd9fy Plumbing 14 02-11-2007 08:40 PM
Cast Iron Pipe denick Excavation & Site Work 18 05-13-2006 09:32 PM
Cutting 4" stack (Cast) MinConst Plumbing 8 12-31-2005 05:56 AM
