Custom Cast Iron Sink??
Old 05-29-2013, 09:06 PM   #1
go do it's Avatar
Trade: general contracting
Rewards Points: 258
does know of anyone making custom cast iron enameled sinks?
i am doing a kitchen remodel and we need a two bowl sink 30" x 16"
an odd size for sure but we have no room for a larger one
i could re-enamel the existing one but would rather not
go do it is offline
Old 05-29-2013, 09:09 PM   #2
Kent Whitten's Avatar
Rewards Points: 2,040
Re: Custom Cast Iron Sink??
Why not? I think it would be hundreds if not thousands less than a custom cast iron sink.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 05-29-2013, 10:44 PM   #3
go do it's Avatar
Rewards Points: 258
we are concerned with chipping
go do it is offline
Old 05-30-2013, 01:54 AM   #4
CarpenterSFO's Avatar
Rewards Points: 2,044
Thousands, easily. A few years back a friend remodeled a home in SF. They put in fairly standard tubs except in one room with a 63" (or something like that) space. They had someone make a 63" cast iron tub, essentially a stretch Kohler. All he'd say was that the single tub was more expensive than most whole bathroom remodels.
The family didn't care - they knew it was crazy, but they felt they should work pretty hard to help spread some of their wealth around.
- Bob
CarpenterSFO is offline
Old 05-30-2013, 04:43 AM   #5
You should have that same concern with any cast iron sink. They have a tendency to chip. New or refurbished.
The Following User Says Thank You to Kent Whitten For This Useful Post:
CarpenterSFO (05-30-2013)
Old 05-30-2013, 06:03 PM   #6
Oconomowoc's Avatar
Trade: construction
Rewards Points: 2,000
Kohler makes the best cast iron sinks but they will not build a custom sink.
You can easily have custom sinks made in copper or SS though. Not cheap.
You could also make some calls and see if Corian can be custom made.
Oconomowoc is offline
Old 05-30-2013, 11:20 PM   #7
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,864
If you have the old sink electro glazed you will get a quality and durable finish on it.
KillerToiletSpider is offline
Old 05-31-2013, 08:07 AM   #8
bathroom guru
jarvis design's Avatar
Rewards Points: 560
There used to be a company in the States, and I'm sorry I don't recall either the name or location, but, they re-porcelain cast iron fixtures. Existing porcelain is stripped and they put new porcelain on.
It is not an easy task....I tried it a number of years ago with a company in Toronto that did porcelain and enamel on things like hand dryers, chalk boards, etc.
In my past business I restored hundreds of cast iron tubs, sinks, etc. Kitchen sinks were the worst. they looked amazing done, but, that only lasted so long.
Bathrooms Built for Life.
www.ExpressBath.ca
519-495-4062
jarvis design is offline
Old 12-06-2014, 10:13 PM   #9
CopperSmith's Avatar
Trade: Custom Copper Gutters, Leaf Protection, Seamless
Rewards Points: 93
Have you considered a copper sink for this application? They last longer than iron. http://www.worldcoppersmith.com/
Browse the Collection.
www.WorldCopperSmith.com
CopperSmith is offline
Worth refinishing a cast iron tub? goneelkn Kitchens & Baths 3 04-18-2011 07:02 PM
Connecting ABS to Cast iron.... pzeiler Plumbing 6 02-28-2011 09:01 AM
cast iron tub, 30"x48"? ApgarNJ Plumbing 6 10-20-2010 08:40 AM
Cast iron shower pans?? ruskent Remodeling 18 11-24-2009 07:29 PM
Has anyone heard of cold fusion welding for cast iron tmpnc Welding & Steel Trades 1 02-04-2009 12:24 PM
