CSST Bonding Instructions
Old 02-20-2008, 04:19 AM   #1
JamesNLA's Avatar
Trade: Plumbing & Electrical
Also posted this in the electrical (nec discussions) section.
I have been talking to my local inspectors.....they are now requiring it.
http://gastite.com/include/languages.../TB2007_01.pdf
"....And then we all switch places when I ring the bell"
-Adrock
JamesNLA is offline
Old 02-20-2008, 09:08 AM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: CSST Bonding Instructions
Yes I knew about this a year ago. Read about it in a lawsuit.
The lawsuit claims that CSST poses an unreasonable risk of fire due to lightning strikes. Plaintiffs allege that the CSST tubing is not thick enough to prevent damage to the CSST in the event of a lightning strike and that Defendants failed to warn consumers about these alleged dangers.
http://www.pddocs.com/csst/faq.aspx
Ron The Plumber is offline
Old 02-20-2008, 12:11 PM   #3
JamesNLA's Avatar
Yeah...we were posting about this at least a year ago. I had inquired from my inspectors about the bonding and when it was going to be required. Most never knew a thing about (shocker) it.
Do you know if we can bring the bonding wire that is usually either bonded to the cold and/or jumped to the hot line, just extent that down to a rigid pipe on the gas line? I don't see why not.....either way it won't make a damn bit of difference....lightning strikes or not....
-Adrock
JamesNLA is offline
Old 02-20-2008, 12:24 PM   #4
Grumpyplumber's Avatar
Trade: Plumber
I've used & been certified (yeah, tough process, hard test...sure) in Wardflex, Gastite & Tracpipe when I worked for other shops.
I wouldn't use Wardflex on anything, it's annealed & I've seen it puncture being dragged through tight spots, leaving a concealed leak with a crew running around trying to find it.
Each mfg has it's own fastening technique, confuse one with another & you've got trouble.
With my name on the work I just use steel hard pipe...between the cost of the fittings & pipe as a trade off for saving time, I'd just as soon stay old school for now.
There are exceptions where you can drag CSST through a tight or confined space & minimize damage to finished walls & ceilings, then I'll use it, with care.
Grumpyplumber is offline
Old 02-20-2008, 07:46 PM   #5
Pro Plumber
Trade: Plumber
Sounds ok, but I really can't say, bonding is not an issue here, it's not being enforced,
Old 02-20-2008, 07:58 PM   #6
threaderman's Avatar
Trade: Plumbing & Gas Contractor
Some cities here require it but most don't care.I always give the cust. a copy of the csst. requirements for bonding/grounding.I also state on the invoice that they are required to seek a lic. electrician for assistance.
threaderman is offline
CSST Bonding details JamesNLA NEC Discussion 4 02-20-2008 07:51 PM
System Bonding Jumper vs. Main Bonding Jumper Mark Twenhafel NEC Discussion 3 02-09-2008 06:15 PM
Bonding for new home building TNGHomes Construction 5 01-28-2008 04:20 PM
Paint not bonding to surface...why?? lornmastro Painting & Finish Work 10 10-08-2007 10:49 PM
durabond and bonding primer lornmastro Painting & Finish Work 2 04-10-2007 10:51 PM
