Crawl Space Water Cut Off ?
Old 09-13-2009, 10:31 AM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
The 3/4" water cut off valve that has a 3/8" sq rod assembly that extends up to a first floor closet to operate it - what's that called or a web link ?
We Fix Houses is offline
Old 09-13-2009, 10:47 AM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Crawl Space Water Cut Off ?
Shut off key
Ron The Plumber is offline
Old 09-13-2009, 01:16 PM   #3
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extrordinaire
Stop and Waste valve.
Andy.
www.draftinginoc.com
ScipioAfricanus is offline
Old 09-13-2009, 03:11 PM   #4
mics_54's Avatar
Trade: contractor
stop and waste valves or curb stops are usually buried in the ground...I don't think I would want a stop and waste which drains water out of lines to be in a crawl space. you want a remotely operated valve. I didn't know they have these specific to your need. I could use one in a similar circumstance and was considering making one.
mics_54 is offline
Old 09-13-2009, 03:17 PM   #5
The Grand Wazoo
KillerToiletSpider's Avatar
You're looking for a Partition Stop
KillerToiletSpider is online now
The Following User Says Thank You to KillerToiletSpider For This Useful Post:
mics_54 (09-13-2009)
duomatic olsen leaking water Slyfox HVAC 1 07-27-2009 07:51 PM
Blocking up a garage door and water bert0168 Masonry 5 02-01-2009 11:04 PM
Air pressure test in water lines Rx8 Plumbing 5 01-05-2009 04:08 PM
HWH Repl in Crawl Space We Fix Houses Plumbing 2 09-23-2008 08:39 AM
Sealed or open crawl space? J.C. Leonard General Discussion 7 06-03-2008 08:52 PM
