Cracks In Sink
Old 06-17-2006, 05:51 PM   #1
ChuckEA's Avatar
Trade: handyman
Cracks In Sink
I have a situation where hairline cracks have begun to appear in the vanity sink of one of my customers. The cracks radiate outward from the drain flange and extend out about an inch. The sink is made of cultured marble and the cracks appear to only be in the surface coat and not through the substrate. Fortunately no leaks have appeared yet. I suspect maybe the cause is the flange being tightened down too much. Is it possible to repair these and what is the best way to do it?
ChuckEA is offline
Old 06-17-2006, 06:20 PM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Cracks In Sink
This is one of the flaws of cultured marble, too susceptible to cracks around the drains. I've never seen it fixed, but I'm sure if I had to fix it I could do it with some clear epoxy like West System smeared into the cracks and then wiping off the surface.
Mike Finley is offline
Old 06-26-2006, 07:23 PM   #3
copusbuilder's Avatar
Trade: Builder/Remodeler- Master Electrician
Re: Cracks In Sink
My experience with this is that the cracking was more prevalent before the industry adopted standards. We used to do makereadies and this was a common problem. We had a company that would come in and repair the cracks and then redo the bowls a solid white or matching color.
The finished product was not great but was better than looking at cracks...
The cracks rarely seem to be anything more than cosmetic.
http://www.naturalhandyman.com/qa/qa...ountertop.shtm
http://www.kbrefinishing.com/culture...efinsihing.htm
Might help a little
copusbuilder is offline
Old 06-27-2006, 07:56 AM   #4
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
Re: Cracks In Sink
thermal shock, not repairable, try an onyx product.
go dart is offline
Old 06-27-2006, 08:31 AM   #5
Re: Cracks In Sink
Guess I need to lay off the acid
Old 06-27-2006, 09:57 AM   #6
Teetorbilt's Avatar
Re: Cracks In Sink
The manufacturers here used the cheapest polyester resin that they could buy, I used to sell it to them.
You can patch it but don't expect good looks or long term success plus it's going to be a lot of labor.
If you're determined to keep the top, you may be able to cut out the old sink and install a new one depending on the dimensions. The stuff works pretty easily.
Albert Einstein
Teetorbilt is offline
caulking cracks on stucco is extremely noticable saucedo80 Painting & Finish Work 6 09-19-2011 01:01 AM
Need help! Hole for sink cut too big! sage Plumbing 32 02-05-2009 03:10 PM
Wall to ceiling cracks in foyer ATHC Drywall 9 06-10-2008 08:00 AM
Cracks O'Plenty... Richie-C Painting & Finish Work 9 03-15-2006 11:07 AM
Bathroom sink question Robie Plumbing 6 12-07-2005 10:23 PM
