#21 |
Rewards Points: 1,548
Re: CPVC Or PEX For Re-pipe |
The Following 2 Users Say Thank You to rrk For This Useful Post: |
Jaws (12-05-2017),
Seven-Delta-FortyOne (12-03-2017)
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
#22 | |
Trade: Exterior Remodeling
Rewards Points: 756
Re: CPVC Or PEX For Re-pipeQuote:
Sent from my LG-V520 using Tapatalk |
The Following User Says Thank You to Randy Bush For This Useful Post: |
SmallTownGuy (12-05-2017)
#23 |
Renaissance Man
Rewards Points: 5,238
My house is done in type K copper for the main underground supply and type L throughout the house. I replaced all the copper in the house with new type L 10 years ago when the house was approx 65 years old. No problems at all were found except for some of the old gate valves which were replaced using legend full-port ball valves. These systems routinely last 100 years or more around here.
If your water is hard, get a softener or filtration system to filter out the nasties. Deburring all cuts and the use of prv valves to control pressure at 80psi or below go a long way at preserving copper systems...cavitation has caused many a pinhole in pipe which should have lasted much longer. Did I say I like copper ![]()
"Under promise, over deliver and all that!" JBM supersealconstruction.com https://www.facebook.com/Superseal-C...2699413750013/ |
#24 |
Rewards Points: 7,252
My plumbers have gone to all Pex. They arent any cheaper though.
Your emergency does not constitute a problem with my Constitution. |
The Following User Says Thank You to VinylHanger For This Useful Post: |
kirkdc (12-06-2017)
#25 |
edward trowelhands
Trade: Diplomat
Rewards Points: 4,198
Honestly I think this is regional like many things in construction. Almost no CPVC around here.
#26 |
Isn't cvpc the pipe that breaks every time you go to turn the water off at a fixture. That in itselfnisnenough or me to not use it.
SmallTownGuy (12-06-2017)
#27 | |
Rewards Points: 2,212
Only when you drop a sink on it.
-John |
The Following 3 Users Say Thank You to slowsol For This Useful Post: |
#28 |
Rewards Points: 2,564
Galvanized or go home...
Tom |
#29 |
#30 |
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,788
Lately, I been using pex B and shark-byte fittings. Sharkbytes can also connect to copper so if a guy wants to run pex and shark-bytes he can. I still think sweat solder and copper are top-dog. But it does take more time.
I repaired 22 breaks (an abandoned house where water lines froze and burst) in one day with pex and shark-bytes. That was cutting open walls and ceilings and making repairs. $4k. It didn't include drywall work. I never would have done that in that time with sweat-soldering. I was leery about usuing pex and the many different ways to connect it but it seems to hold up well and insurance companies give it the green light. I've used the compression bands with pex and found them to be just OK but often it's limited to get the crimp tool in tight places. And you have to finaggle around lining up a tee or elbow to point in the proper direction while you trying to position your crimp tool and compress it. Sometimes it'll move around on ya. Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
3inch cpvc pipe problems | Vicontractor123 | Plumbing | 7 | 08-18-2014 07:12 AM |
pipe repair - ok to replace copper with cpvc? | MarkJames | Plumbing | 39 | 10-11-2013 04:36 PM |
3" PVC pipe dumpig water into sump pump - what is it? | ggsubs | Plumbing | 9 | 06-06-2013 07:17 PM |
What is this pipe? | AmeliaP | Plumbing | 1 | 03-01-2013 05:45 PM |
Pinhole leaks in copper pipe | FStephenMasek | Plumbing | 16 | 11-08-2012 06:59 AM |
Go to Page... |
