Covering Up Bad Smell
I'm taking a stab at this-wondering if some of you plumbers would know/heard of the use of vanilla extract solution being sprayed in a crawlspace to neutralize the the oldor of a failed drain pipe.
Do you have any recommendation for covering up this sewer smell (soure was repaired. |
Trade: Electrician
Re: Covering Up Bad Smell
google OZONE GENERATOR. they work splendid. http://www.air-zone.com/
Moderator
Check with your local plumbers and see if any are selling a product called Bio-Clean.
Mix this down with warm water and spray in the effected area and soak it well. It will take care of the smell in short order. It also cleans the spill and turns it into something non-toxic. Covering the smell with another smell won't address the problem, just the symptom.
thanks-I found some sources for this stuff-I bet it would take a lot to treat 2200 sqft of crawlspace!
| can't get rid of bad primer smell....help please | Zeebo | Painting & Finish Work | 17 | 12-10-2008 06:39 AM |
| TCA floor covering comparison chart | MattCoops | Flooring | 5 | 11-19-2008 10:05 PM |
| Sewer drain smell | flashheatingand | Plumbing | 4 | 08-15-2008 10:55 PM |
| pet smell out of carpet any help???? | TurnkeyConst | General Discussion | 20 | 05-25-2008 10:35 PM |
| The smell of ?? | K2 | Off Topic (Non Trade) | 9 | 12-19-2006 07:17 PM |
