Coupling for threaded steel pipe
Hi fellows,
I will have a new garage door installed soon, and that will force me to re-route a pretty large steel pipe that's part of the house's hot water heating system.
The pipe is about 2 3/8'' outside diameter, 2'' NPT I figure. To work the new route, I would like to just cut the pipe and use the type of mechanical coupling that has a neoprene sleeve inside a steel sheet, and tightens with two collars.
I know that these couplings are OK for DWV use, and generally employed to connect cast iron with ABS pipes.
Now, this same kind of coupling, is it allright to use it for a central hot water system?
The boiler's pressure is not high (around 10 psi), but will those couplings take the heat?
If not, is there another kind of coupling that's approved for hot water ?
I would REALLY love to stay away from unscrewing, threading and screwing back 2'' NPT piping...
Thanks!
