Corrugated Connection To WH Pressure Relief
Old 01-13-2009, 11:40 PM   #1
Error Corrector
olyteddy's Avatar
Trade: Maintenance Manager
I need to replace a lot of Water Heaters (and before you crack wise with 'Hire a Plumber'...) I could find no mention of using Corrugated Copper to connect to the overtemp/pressure valve. The new tanks are generally shorter than the old ones but they're hard piped to the drains. As long as they're less than 24" is corrugated (or Flexible) usable?
Originally Posted by wa_olympia_plumbing.pdf
604.12 Flexible Corrugated Connectors. Flexible
corrugated connectors of copper or stainless steel
shall be limited to the following connector lengths:
Water Heater Connectors -:- twenty-four (24)
inches (609 mm).
olyteddy is offline
Old 01-14-2009, 12:22 AM   #2
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Re: Corrugated Connection To WH Pressure Relief
According to section 608.5 of the UPC, drain has to be full sized drain, flex connect are not considered full size. Notice the type of pipe it says you can use.
So there you go, you have your answer.
Ron The Plumber is offline
Old 01-14-2009, 10:36 PM   #3
Error Corrector
olyteddy's Avatar
Thanks Ron.
olyteddy is offline
Old 01-14-2009, 10:54 PM   #4
Thom
thom's Avatar
interesting Ron. That makes it very clear, but it would fail here. We must use the corrugated flex connectors on all three connections. The inspector failed me on one (my own house) for hard piping the T&P line. He said we had to have the union connection and the only one he would accept was with the corrugated flex copper. All the homes I build the plumber uses the flexes at all three connections.
I guess we do it different here.
thom is offline
Old 01-15-2009, 09:37 AM   #5
Error Corrector
olyteddy's Avatar
The reason for my OP was that I've worked several different properties and some of the older ones used flex and here at the newer ones it's all hardline (the ~12 year old ones are copper, the 2 year old ones CPVC).
olyteddy is offline
Air pressure test in water lines Rx8 Plumbing 5 01-05-2009 04:08 PM
Pressure Washing New Residential Homes SunSet Pressure Washing 12 11-10-2008 10:32 AM
lennox filter system pressure drops westernhvac HVAC 1 10-21-2008 12:30 AM
Old and now new water heater leaks from pressure relief valve Shockwave Plumbing 16 04-03-2008 12:36 PM
advice on low pressure well problem 72chevy4x4 Plumbing 0 07-16-2007 07:54 AM
