Corrosion And Smell
Old 10-23-2006, 06:25 PM   #1
dgrothusen@wbsn's Avatar
Trade: handyman
Corrosion And Smell
I have been doing some maintanence on a home that has a problem that really baffles me. The electric water heater in the basement, there is one upstairs too, has a corrosion problem. The one upstairs does not. The copper supply line goes to galv for the union. There is a terrific corrosion problem on the galv pipe. This is a new water heater and the old one had the same problem. The other problem is there is a smell from this unit. It does have a floor drain in the closet where it sits but I have kept the p trap full so I don't know how I can get sewer gas. It accually smells like dead mouse but there is not one of those in there. Any insight would be appreciated.
dgrothusen@wbsn is offline
Old 10-23-2006, 06:32 PM   #2
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Re: Corrosion And Smell
It probably is a dead mouse but you can't see it! He could be inside a wall, or under the floor. Ask the HO if they ever had a rodent problem and maybe put out some poison
Don't worry, the baseboard will hide it!
ron schenker is offline
Old 10-23-2006, 06:51 PM   #3
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
AS for the water heater replace the galvinized to brass.
Ron The Plumber is offline
Old 10-24-2006, 10:25 AM   #4
Moderator
Double-A's Avatar
And change the union to an insulated or dielectric union. On both hot and cold water.
New York Times, July 20, 2006
Double-A is offline
Old 10-25-2006, 06:31 PM   #5
Trade: handyman
Thanks for the info. Does the corrosion have a smell??? And why does the other water heater in the house not corrode like this one. Same connections.
Old 10-25-2006, 07:50 PM   #6
Pro Plumber
Trade: Plumber
Corrosion will not smell, best replace the other connections as well before they do the same thing.
Old 10-26-2006, 11:55 AM   #7
Moderator
Double-A's Avatar
There are certain type of well water and municipal water sources that will make the anode in the water heater stink like rotten eggs.
If you suspect this, then you can change the anode out for another type. Take a look at the water heater manufacturer's web site for details.
Double-A is offline
