Trade: Builder
Copper Type M
Hope all are enjoying the summer. Looking for some thoughts on Copper piping Type M.
I tried a new plumber on a home I am building in CT and he wanted to use copper, as I sensed he did not use PEX. The plumber had 30 years in the trade and I would say did a good, neat job. I was interviewing a new electrician who asked me what type of copper I used and he made a face when I said M. The electrician went on to say M will last maybe 10 years as the water will eat thru the pipe over time. The home is on city water. Do I need to be concerned? Thank-you all. |
Trade: Plumbing & Electrical
Re: Copper Type M
Typically it's type L. Old timers don't like Pex, if it's different they don't wanna know. Pex is usually less expensive for a new build.
I see alot of M underground for slab homes. However the city water isn't that hard on pipes around here. As far as being concerned....if it will pass code you shouldn't be concerned. If M would only last 10 years in your area, why bother using copper? You can get 10 years out of galvi.
"....And then we all switch places when I ring the bell" -Adrock
Trade: Builder
Re: Copper Type M
I may contact the town inspector and ask him if the town has an issue with M copper.
I quess the main question I am asking the board is did the comment made about M copper lasting 10 years sound right ? I'm thinking copper in the Pyramids lasting thousands of years and only 10 years on M copper. I have seen posts here where pin hole leaks are reported after 25-30 years and even that sounds bad. Who would want to open walls and get mold issues even in 80 years. |
#4 | |
The Grand Wazoo
Re: Copper Type MQuote:
Cabinetmaker
Re: Copper Type M
Here in NJ "M" is not allowed for potable water lines. "M" is used for heating only.
JackM |
Builder/Remodeler
Re: Copper Type M
Most of the time, early failures in copper are due to improper tie-ins to other materials or not reaming cut pipes before sweating them to fittings...
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
Trade: Plumber
Re: Copper Type M
Where I am, type "M" is expressely prohibited on potable.
Type "L" or better. |
| pex vs. copper | Mr. D | Plumbing | 68 | 05-16-2008 11:46 PM |
| copper coupling popped loose | knyt | Plumbing | 6 | 06-13-2007 04:32 AM |
| Aluminum to copper lug | Mike Finley | Electrical | 21 | 06-03-2007 12:31 AM |
| Painting new gal. gutters copper | DeanV | Painting & Finish Work | 0 | 06-22-2006 09:39 PM |
| Copper vents -vs- plastic/aluminum | shopman | Roofing | 2 | 03-01-2006 08:51 AM |
