Copper Pipe, Pin Holes , Is It Happening By You??
Old 11-17-2006, 06:02 PM   #1
Plumber
tzzzz216's Avatar
Trade: Plumbing
I've installed thousands of feet of copper pipe in south Florida , soft and hard over head and in the ground roughs never ran across or saw any problems other than a leaking fitting or a drywall screw in it , I moved up to northwest Florida 2 years ago and opened my business last year I get at least 2 calls a month from one end of the county to the other end for leaks in copper pipe they all have been pin holes in all them it seems that all of them been on the cold supply side ,has anyone else seen this problem in their area of the country , any ideas what might be causing it ?
Try to send these jobs overseas !!!
tzzzz216 is offline
Old 11-17-2006, 06:06 PM   #2
mdshunk's Avatar
Re: Copper Pipe, Pin Holes , Is It Happening By You??
It has to do with the PH of the local water supply. It is a well know and documented phenomenon. This is very common on wells.
mdshunk is offline
Old 11-17-2006, 06:38 PM   #3
Dustball's Avatar
I remember seeing this question on an old show of Ask This Old House.
Here's their answer-
http://www.thisoldhouse.com/toh/tvpr...212564,00.html
For instance, flux—the acidic paste used in soldering—react with copper if the pipes stand idle for a long period after installation. This kind of trouble typically crops up near fittings and in cold-water pipes because hot water is better at washing flux away.
Dustball is offline
Old 11-17-2006, 06:39 PM   #4
Teetorbilt's Avatar
The areas that you mention have a high sulfur content in the water and it doesn't seem to like copper pipes. We have the problem here too, mostly in older homes. Electricians bonded into the copper plumbing 'just like we do it up north' without realizing that our ground is mostly all old beach and full of salt. Salt attracts water and the water table is commonly only a few feet down. It doesn't take a genius to figure out the rest.
Albert Einstein
Teetorbilt is offline
Old 11-17-2006, 08:49 PM   #5
Pro Plumber
Ron The Plumber's Avatar
Trade: Plumber
Simple solution, use type L copper or switch use pex.
Ron The Plumber is offline
Old 11-17-2006, 10:26 PM   #6
Teetorbilt's Avatar
Cross linked polyethelene will also break down when exposed to certain chemicals.
Albert Einstein
Old 11-17-2006, 10:36 PM   #7
Plumber
tzzzz216's Avatar
Trade: Plumbing
Ron, I was of the same thinking up until today when i found for the first time a leak in L copper . Thanks for your reply and others who replied to this post.
tzzzz216 is offline
Old 11-17-2006, 10:40 PM   #8
Pro Plumber
Trade: Plumber
Wow, L is some heavy duty copper, you might need to do some homework and find the best alternative/s for high PH levels in the ground.
Old 11-17-2006, 10:54 PM   #9
contractor
cmwacasey's Avatar
Trade: carpentry plumbing electric
teeter are theses chemicals you are refering to,found in our water supply.
cmwacasey is offline
Old 11-17-2006, 11:13 PM   #10
Teetorbilt's Avatar
I never found out the exact source but cleaning agents were highly indicated. I've only seen it twice but you could, litterally, crumble the tubing in your hand. Polyethelene is cheap crap IMHO.
Albert Einstein
Old 11-17-2006, 11:16 PM   #11
mdshunk's Avatar
I was wondering what breaks down PEX too. I do know that it is not UV resistant, so if left out in the sun it will get brittle. They make gasoline cans from polyethylene.
From my old college chemistry book: "...polyethylene is insoluble in all solvents and is resistant to the action of most reagents, other than strong oxidizing acids..."
This makes it pretty bullet-proof in my book. Plus, PEX includes an anti-oxidant in the polymer to resist the oxidative degredation of hot water on the pipe. It will be interesting to learn exactly what does effect PEX, other than UV light.
mdshunk is offline
Old 11-17-2006, 11:20 PM   #12
Pro Plumber
Trade: Plumber
Nice to know there is more then just me on here that thinks Pex is good and not just some crap.
Old 11-17-2006, 11:22 PM   #13
contractor
cmwacasey's Avatar
pin holes in copper,crap polyethylene,galvananize corrodes,cpvc is not good.what are we going to do?water damage business is looking good.
Old 11-17-2006, 11:47 PM   #14
Teetorbilt's Avatar
md, your problem is that your old college book is old and you ain't getting any younger either.
I currently purchase my tubing from here http://www.newageindustries.com/ there are charts there that explain the differences between PE and PU. Since switching to PU, I have had 0 failures but it costs much more.
As far as what caused the failures, I'd like to know too. It sure ruined the PE.
Albert Einstein
Old 11-18-2006, 12:36 AM   #15
contractor
cmwacasey's Avatar
teeter I think I will go with the pe.if they start running gasoline in my water pipes,I want it to corode---faster the better.
Old 11-18-2006, 09:32 AM   #16
gitnerdun's Avatar
Trade: plumber
Back to pinholes..........Here in SW FL I was getting at least 1 call a day for a pinhole below slab (slab leak) last year. This past few months it has slowed to 2 a week. The majority of these calls are in homes less than 10 yrs. old and almost every one is on county water. My house is 50 yrs old never a slab leak and was on a shallow well for 40 yrs, go figure. I have repaired leaks in copper less than 2 yrs old. All of these are Type L.
Speculate all you want about flux, sand, shells, electrolisis, poor install, thin pipe, recycled copper, dumb southerners, whatever...........it has all been a hot topic among homeowners and plumbers.
Repipes are as easy to sell as raincoats in the rain. People are repiping before the first leak. There are many plumbers that only do repipes and just name their price. People are/were panicky enough to pay whatever just to get on the long waiting list.
Leaks are not choosy about what nieghborhoods either, from 100k to multi-million $ houses.
The epoxy-liner guys are having fun too, with all the island fixture, marble floors, and fancy wallpaper houses.
I am just 1 plumber who works by himself and doesn't advertise other than a phone# in the yellow pages. People weren't asking "how much" they were saying more like "we need you to repipe now!".
Last year I sold a few whole-house carbon filters to some regulars and they have had no leaks. Made a difference? Don't know for sure.
After 9-11 Is when this all started to happen, I think the local Government started to add more chlorine to the water to be safe than sorry later. I am not one of those paranoid people, so don't go there.
So you guys who don't have to spend a couple days a week on your knees hammering up concrete should be thankful. PEX is a gift to re-piping and is the better pipe for us here. You all should consider the fact that a homeowner or handy-man cannot get parts or work on a Wirsbo Pex system. Fewer fittings, flexible, and now water hammer. You an look at a connection tosee that it was installed properly. You can't do that with a glued joint.
There it is in a nutshell, but it's not all that bad here in FL. It is 60 degrees this morning the sun is shining and I am going fishing, saltwater of course, that is where the bigones are. Bob
gitnerdun is offline
Old 11-18-2006, 08:48 PM   #17
contractor
cmwacasey's Avatar
thanks bob--well written good information from someone working out in the feild.
Drain Pipe denick Excavation & Site Work 18 07-12-2009 04:41 PM
drain pipe holes up or down? jimb317 Plumbing 9 06-06-2007 04:22 PM
Cement Contact with Copper Pipe Capt2 Plumbing 11 04-17-2007 09:05 PM
Painting new gal. gutters copper DeanV Painting & Finish Work 0 06-22-2006 09:39 PM
Copper pipe locator mlsgroup Plumbing 3 01-21-2006 08:42 PM
