Copper Pipe Electrolysis - Page 2 - Plumbing - Contractor Talk
Old 01-28-2018, 11:28 AM   #21
Renaissance Man
superseal's Avatar
Rewards Points: 5,634
Re: Copper Pipe Electrolysis
Originally Posted by Tom M View Post
It was my understanding that K was the strongest and used for gas L was the second strongest and M is the softest and was the most likely susceptible to corrosion by electrolysis due to the thin walls.
As I understood it if you weren't using gas then you could use any of the pipes safely would just be more expensive to the installer.
Is this more to it?
Type K is generally underground water service and medical gas, type L for gas or water and M is just thin wall red label...used in many boiler applications.
supersealconstruction.com
superseal is offline
Dryer vent pipe replacement. Builders Inc. General Discussion 18 02-10-2016 11:07 AM
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 09:51 PM
HDPE Pipe Problems with vacuum and collapsing turfguy13 General Discussion 6 02-10-2011 08:03 AM
Chimney pipe help bsp General Discussion 8 10-23-2009 12:20 PM
Cement Contact with Copper Pipe Capt2 Plumbing 11 04-17-2007 08:05 PM
