Copper Epoxy
I am not a plumber...but. You guys ever use copper epoxy in areas where sweating is going to be a problem? I have a shower mixer valve on an outside wall and I cannot cut an access panel through brick. The hole for the shower faucet is probably big enough to solder but I thought I'd ask about epoxy first.
Thanks. |
Re: Copper Epoxy
I have never used it but have heard good things about it on other sites.
Trade: Electrician
Re: Copper Epoxy
what about those new solderless couplings and connectors....??
Trade: Home Improvement
Re: Copper Epoxy
I swear by a product called Copper Bond, used to be made & marketed by Noble Company, which makes a variety of excellent products used in the tile and natural stone installation biz. They have since sold the rights to this product and Pipe Doctor to Pacer Technologies out of Calf.
You can see a pic of the product at this link. http://www.noblecompany.com/copper.html I've been using it since it was first introduced about 5 yrs ago, as long as you've got a clean dry pipe & connector, mix it up well, and apply a thin film on both pieces, fit together wait 20 mins & turn the water on, no worries! One caution, if you're working in an unheated crawlspace and it's like -10, it's a mother to squeeze the stuff out of the tube & mix. That's about the only time I break out the torch anymore.
"All you need in this life is ignorance and confidence, and then success is sure". -Mark Twain |
#5 | |
Repair/Remodeling Tech.
Trade: Repair and Remodeling Services
Re: Copper EpoxyQuote:
I used to have a link to a place that sells all that, I'll see if I can find it. MinConst may have it too....Paul??
Jim P. |
#6 | |
Remodeler
Re: Copper Epoxy
Real men 'sweat'!!
http://www.tr-built.com |
| pex vs. copper | Mr. D | Plumbing | 68 | 05-16-2008 11:46 PM |
| Aluminum to copper lug | Mike Finley | Electrical | 21 | 06-03-2007 12:31 AM |
| Epoxy On Tile | go do it | Ceramic & Stone Tile | 14 | 05-16-2007 09:10 PM |
| Painting new gal. gutters copper | DeanV | Painting & Finish Work | 0 | 06-22-2006 09:39 PM |
| Copper vents -vs- plastic/aluminum | shopman | Roofing | 2 | 03-01-2006 08:51 AM |
