Connecting To Sanitary Line In A Warehouse
Old 10-01-2017, 07:18 PM   #1
ragadozo's Avatar
Trade: Commercial Framing
Rewards Points: 26
I've got a rented warehouse space that is connected to 7 other warehouses in the same building. I need to install a trench drain for water to drain into the sanitary line.
Once I find the san. line and excavate the concrete Ill need to connect this trench drain to some abs pipe I assume and then into the san. line but I believe this line runs through the entire building in the middle of each adjacent warehouse. Do I need to shut off the main water supply for this before I start cutting?
ragadozo is offline
Old 10-02-2017, 09:55 AM   #2
GAN57's Avatar
Trade: Licensed Plumber & Inspector
Rewards Points: 76
Re: Connecting To Sanitary Line In A Warehouse
I would say hire a Licensed Plumber to do any work on a Sanitary line inside a building. Most States require this.
GAN57 is offline
Basement Wall Construction at Property Line PDX General Discussion 17 09-05-2017 10:17 AM
Best tool to get a laser line on the ceiling? john91 Tools & Equipment 39 11-30-2015 06:31 AM
Bid Line Item vs. Actual Line Item boswellco Business 6 01-07-2012 08:51 PM
Dryer Vent Linked To A Waste Line Vent? JaeDotAre Plumbing 15 01-04-2012 12:45 PM
Posts not in a straight line trctimberworks Decks & Fencing 35 07-08-2011 06:10 PM
